Thread: What to do first..?
    What to do first..?
    I have had a pretty good leak, and my chemical readings have been low. (It may be repaired - won't know for a few days.) Here is what I've got right now:
    PH - 7.8
    FC - 1.5
    CC - 0
    TC - 1.5
    TA - 90
    CH - 270
    CYA - 40
    SALT - 2250 (been using bleach because of the cold weather..)
    I entered everything in the PC, and there are several things to add.. Does it matter which order I add them?
    Thank you in advance!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Re: What to do first..?
    Chlorine is the priority, everything else can wait a few days (or more).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    As Jason said, fix your FC first in your case. Then If PH is completely out of range fix that, unless FC is above 10 in which case you ignore it. Then CYA, then TA, then CA, and finally borates and salt.
    Thanks so much!!
    Helen
    Update:
    PH 7.5
    FC 4.5
    TA 90
    CH 275
    CYA 40
    Happy Easter to everyone!!!
    Helen
