Results 1 to 8 of 8
Thread: Crack in skimmer housing
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I discovered a crack in the bottom of my skimmer housing. It extends about half-way around the suction opening. I've attached a picture, but the crack is kinda hard to see it is inside the white area. What is the best way to repair it and do I need to drop the water level so it can be dried out? I've decided to empty and refill the pool after getting rid of the iron stains so it could be repaired then if it needs to be dry.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Crack in skimmer housing
    There are marine grade epoxies that cure under water.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    OK, I'll look into that. Does the epoxy need a cover after it is applied to the crack? Would PVC glue work if the area were dried out?
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by stev32k
    I believe PVC glue is designed to simply connect pieces together not fill a gap. Your best bet would be drain down below the crack allow it to dry then use PVC/Plastic weld or marine grade patch.
    I would also want to know why it cracked, ground shift? Any of the concrete in that area cracked as well?
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    I remember seeing this post a few months back.. Maybe this what you need.
    http://www.troublefreepool.com/skimm...ml?hilit=Epoxy
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by 4knights
    The concrete is not cracked, and I can't see any other obvious signs of a problem. So maybe it is ground shift. Would silicone calk would work if the area were dried out and given a light sanding?
    4knights's Avatar
    NE Kansas
    419
    I wouldn't use silcone as it would only be a temporary fix. Any hardware, boat service center or big box store would have marine grade plastic epoxy or plastic weld.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    OK, thanks for the info. There are plenty of marine stores around here.
