Results 1 to 7 of 7
Thread: Just broke my drain line! Help!
    Jan 2013
    Miami, FL
    100
    I broke the pvc line thats between my pump and the drain. Do I have to drain my pool below the break in the pipe to stop the flow?
    11k Gallon, Catridge Filter, In Ground Marcite, 1.5 HP Pump, (Unsure of filter Flow Rate)
    4knights's Avatar
    NE Kansas
    419
    Re: Just broke my drain line! Help!
    Are you talking about the main drain or the suction line from skimmer or both? Did you break it at the equipment pad? It is possible to block the drain from inside the pool so you can repair the line. Depending on water temps you might need a wet or even a dry suit. Could you post a picture?
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jan 2013
    Miami, FL
    100
    Between main drain and the valve near the pump...
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The water will keep coming out until the pool level drops below the pipe.
    4knights's Avatar
    NE Kansas
    419
    Wow! Surprised the line is that shallow, mine are at the level of the returns and some lower than that.
    How did that happen?
    Just like JohnT said, let it drain below the pipe.
    Easy fix though, dig it back about a foot from the break on each side and you can plumb in a new piece.
    Jan 2013
    Miami, FL
    100
    The repair
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Glad you have it done, I spent most of the afternoon working with blue PVC cement also, plumbing a new pool pump which would not fit in the where the old one sat.
