Results 1 to 11 of 11
Thread: michigan pool, peeked under cover and green already.
    Oct 2010
    michigan
    284
    we usually open the pool week before memorial day, plus or minus a week depending on the weather.
    I Have mesh pool cover which allows some sunlight thru the tiny holes. was 54 degrees yesterday so I peeked under the cover and it is turning green already.
    Should I just leave it and worry about it when I open the pool? and will be massively green.
    or should I start putting chlorine in so I don't have even a bigger green swamp when I go to open the pool?
    was thinking maybe next year I should put a solid pool cover under my mesh cover so it doesn't allow any sun thru, so I don't get green water ever year?
    thanks
    steve
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: michigan pool, peeked under cover and green already.
    A little work now beats a lotta work later?
    Oct 2010
    michigan
    284
    that's what I was thinking
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Turning green already in Michigan? Sheesh, my pool is still frozen. The ice is getting thinner, but it's still solid frozen.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Oct 2010
    michigan
    284
    inground with a mesh cover, so the sun light gets thru the mesh. there is still ice, but the edges are melting away.
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    To commiserate with you, we had ice yesterday and today it is completely thawed. We also have "stuff" on the bottom and always seem to open to green water. Our cover is supposed to be solid but stuff gets thru or when the edges get blown up by the wind. I'm considering hooking up all the hoses and filter onto the pool, maybe the pump, and then think about starting up the process. but not sure since we always get at least one ice storm between now and Mother's Day, and still in line for some freezing nights ahead. Last year the PB told me to dump extra chlorine in during our March hot spell, but with the pump not running, it did bleach out some of the liner. We still had to deal with algae when we opened it in May. If you add bleach now, make sure it is well stirred and I guess hope for the best.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Oct 2010
    michigan
    284
    I have fiberglass, so not sure high chlorine can damage the fiberglass?
    already dumped some chlorine in, it already ate it up too 0, so going to go buy some more tomorrow.
    defiantly don't want to start it up yet, we could still get some freezing.
    anyone else have any recommendations?
    Would a solid cover stop it from getting green next year?
    38,470
    My opinion, if you can not do the shock process correctly with the pump running ... you are just wasting money on bleach since you will not be able to kill it all and filter it out.
    Just leave it until you are ready to open.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Oct 2007
    Cedar Hill, TN
    252
    I usually hook up my filter after the last big freeze, fill up with the cover still on. Slide the cleaner under the cover, too and let it run. Start balancing the water, but mostly just killing the nasties. By the time the cover comes off, most of the algae is dead and I can finish shocking and balancing. (Add salt and CYA)
    End of April or so, you can find me fully clothed floating on my big island. With a book, pillow and a drink, enjoying the sun and birds singing. (Small challenge of getting off my island without getting my feet wet. Stairs are not in the pool at that time)
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Oct 2010
    michigan
    284
    is this the same stuff as polyquat?
    looks like it is, but I wanna make sure, fiberglass pool and I don't want any staining
    http://www.lesliespool.com/Home/Pool-Ch ... 14025.html
    If I dumped some of this stuff in there would that kill off the algea and get it to stop growing?
    I have electric pool cleaner that I can throw in there to stir up the water.
    38,470
    No. Algaecide does not kill algae. It attempts to reduce the likelihood of algae starting if your FC gets too low. You are past that point. You need full on shock process with chlorine.
