Results 1 to 8 of 8
Thread: Inground pool opening
    Was wondering if someone has a good link to a detailed video of a pool opening. Possibly a salt water pool. Would to have it by my side for my 1st opening this year.
    Thanx.
    17,640 gal, IG Vinyl, 3/4 HP Hayward Super Pump, Zodica Nature2 DuoClear130 SWG, Clean manually.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Inground pool opening
    Welcome to tfp, LivingLegend
    I do not know of a video, but here is our poolschool article on opening an agp...some of it applies to igps as well: http://www.troublefreepool.com/pool-...0ground%20pool
    If you have questions don't hesitate to ask!
    4knights's Avatar
    NE Kansas
    419
    This is a pretty good set of videos, http://www.poolschool.us/videos_pool_maintenance.htm
    I learned a lot from that site before I found TFP. The videos helped me to understand the system and plumbing.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Good vidoes, i found a good too and I will use all for my support. Thanx Guys!!
    Apr 2012
    Mason, Ohio
    119
    Quote Originally Posted by 4knights
    Wow - is it common for a pool to be that green when it's opened for the season? I would think that a "pool school" guy's pool would look better than that. Is this what I have to look forward to when I take my cover off?
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    4knights's Avatar
    NE Kansas
    419
    I think it depends on the type of cover you have as well as your water temps. I just put my pool in last Sep/Oct so don't know what mine will look like. Pretty sure it will be green since I have a mesh cover(let's some light in) but our water(ice) temp has been as low as 24 this winter. as the water warms up I'll start using bleach until the temp is where it needs to be for the salt cell to work.
    I'm hoping to have a clear pool in Maywhen I open. I have safety mesh cover and water was clear when opened last year. Weather was overly warm too. Fingers are crossed.
    Feb 2017
    Ohio
    217
    I just opened my pool the first time, pool was installed last Oct. I also have a mesh cover. Water was 56 deg., clear with dirt/silt stuck to sides and bottom. There was a pile of leaves,straw,(I just planted grass), mesh cover instructions, dead worms, and dirt. Used Leaf rake to pull out the pile, smelled like stagnant water and garbage. Brushed sides and bottom, vacuumed, water was somewhat brown and cloudy, ran filter about 8 hrs. This morning water was clear with a little silt on bottom in spots. All chems up to specs. One more light vacuum and iam good to go.
    Rick, Fiberglass.....14 x 30 Viking Laguna - 10,000 gal. Pentair cartridge filter, gas heater, Swg, variable speed pump, Easytouch control system.
    k2006c, k1766
