Thread: Bleach question?
    carli's Avatar
    Mar 2013
    San Juan, Puerto Rico
    17
    Bleach question?
    I recently started using the BBB method. If I use bleach like clorox doesn't it has iron
    that will lead in time to pool staining?
    13,500 gal, IG plaster, 1 HP Hayward, 36 sqft Purex DE filter
    Jandy NL valve, Hayward multiport valve
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Bleach question?
    Quote Originally Posted by carli
    No.
    If there's iron staining, it came from somewhere else, not the bleach.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Where do you get your fill water from. If its from a well that can be an iron source.
    Jeff
