Results 1 to 12 of 12
Thread: autofill isnt high enough
    Pool builder installed autofill a little low. The autofill is at its max height and the pool is about 2-3 inches below where I would want it to be. (1 inch into the tile line, would prefer 3-4 inches on the tile).
    I have a small rock sitting on the float, are there any other suggestions that might work better than a weight on the float?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    38,251
    Re: autofill isnt high enough
    what does the valve look like? add a picture maybe.
    Is the water at the top of the autofill bucket or at the top of where the float can be adjusted?
    Mine is a brass valve with a float that can be raised and lowered quite a bit. I know others are more like the plastic toilet valves where the float is around a central shaft.
    Apr 2010
    Buckeye, AZ 85326
    619
    Is it just a regular float valve? I adjust mine by manualy bending the float up or down until its at the desired hieght. If its a different kind of float valve there will be another type of adjustment.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    If it's like this autofill, you can adjust the height of the valve itself down at the bottom, then fine-tune it with the float adjuster. http://www.pentairpool.com/pdfs/ModelT4 ... llerIG.pdf
    Personally, I'd call the builder and have him fix it.
    plastic toilet float valve where it is a cylinder on the shaft.
    looks like this
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by march2012
    Like figure E in my link?
    38,251
    So, is your float connected to the thin vertical pin on the side all the way at the top, like in your picture you posted?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I have the same autofill, and that valve assembly has a coarse and fine adjustment. The "collet" lock, located midway up the central column is the coarse adjust and the threaded pin, to the right of the float, is the fine adjust.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Quote Originally Posted by gtemkin
    ah ok, Ill check, I was only adjusting the fine adjustment.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    [/quote]ah ok, Ill check, I was only adjusting the fine adjustment.[/quote]
    You lift the locking collar which un-locks the telescoping column, then adjust the column up or down - up in your case - then push the locking column back down to lock the adjustment. It can be very hard to re-lock the collar, you may have to telescope the column a little one way up or down to get it to lock easier.
    Good luck.
    Good luck.
    Hah I kept trying to turn the thing and nothing was happening. Thanks!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    .... - then push the locking column back down to lock the adjustment..
    Should have been....
    .... - then push the locking collar back down to lock the adjustment..
