Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: New homeowner and high pool values... need help
    Mar 2013
    CA
    28
    deleted
    22k IG pebble-tec pool, Pentair Whisperflo 2-hp pump, Pentair Triton II TR-60 sand filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: New homeowner and high pool values... need help
    You've only got two numbers horribly off so to speak. PH is first which you can fix in 5 minutes with some muriatic acid-----see the pool calculator for how much to add-guessing 36 ounces or so. CYA is another matter. Can only be fixed by a partial drain. We recommend 50% drain at a time to get it into reasonable territory at that level-anything testing over 100 is highly suspect to be more than that. Welcome to the forum!
    Jun 2012
    Howell, NJ
    977
    How did you get 140 for the CYA? I thought the test only went up to 100. Either way, you may want to mix 50% pool water and 50% tap water and do the test again. You then take the results of that, and double it. Also, why do you say you were unable to test CC?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    38,475
    Welcome to TFP!!!
    Yup. pH and your CYA are the problems. Why could you not test the CC?
    Unfortunately, your CYA is likely WAY higher than 140ppm ... it is a logarithmic scale. You can try using 50/50 split of pool and tap water to start the CYA test and then double the result, but I am guessing that will still be below the 100 line meaning you are over 200ppm
    Can you add your location to your profile? Do you close the pool in the winter (partial drain, etc)?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    CYA is too high. And it's getting worse because you're using the trichlor.
    Stop using the pucks - switch to liquid bleach for now.
    Dilute your sample water 50/50 with tap water then use that mixture with the reagent to test CYA. Double your reading to see what CYA really is. Then drain accordingly and refill.
    Keep the pH in range and the FC above minimum for you CYA level and it should clear up nicely.
    Your filter will eventually catch up. Once it stops loading up so quick, you might try addinga little diatomaceous earth to really get the water sparkling, but that can wait.
    Jun 2012
    Howell, NJ
    977
    [s:1igjvyul]Something doesn't make sense... Trichlor is very acidic. I have trouble keeping the pH up while using it to start the pool up. That being said, how can the pool have a pH of 8?[/s:1igjvyul]
    Never mind, I noticed the FC is at 12.5, which could make the pH test read higher than it really is.
    John
    Mar 2013
    CA
    28
    deleted
    38,475
    That just means your CC = 0 ... which is good
    As was eluded to above, when the FC > 10ppm, the pH is inaccurate and reads high.
    As far as the CYA goes, seems like a 50% water replacement and then a retest is required to get that back into the recommended levels. Then you will need to stop using the pucks and switch to liquid chlorine.
    If you have not already, read Pool School a few times.
    Mar 2013
    San Jose, CA
    4
    Why not just drain your pool and start with fresh water. I did when I was faced with a pool in our new home whose chemistry was really out of whack. Starting with tests on the new city water, it was easy to determine dosing to get the chemistry at proper levels.
    I never really grew up, I just learned how to act in public.
    16k IG gallon pool, StaRite 1hp pump, Pentair 420 filter, Compool Lx220, Aquapure SWG, Polaris 380 w/ boost, 270 sqft Gull solar coils
    Paul, There is no point in replacing more water than is required to get the CYA level down to something reasonable (and possibly CH, though not in this case). Draining the pool completely risks damaging the pool and forces you to spend extra money on water and chemicals that there is no reason to spend.
    Mar 2013
    CA
    28
    deleted
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Clamp on discharge hoses like that are very cheap, usually less than $25 at places like Tractor supply, etc.. If you want a better quality longer lasting hose, you can often find old fire hose cabinet hoses on ebay for under $50 that have been removed from service due to age, many were never used, just measure to make sure you get the right size, most likely 1.5 or 2 inch.
    Ike
    38,475
    If you are going to use the pump to drain the pool, you must be able to turn off the skimmer. Although, you generally would not want to do this in the backwash setting as any dirt that is pulled out of the pool will end up on the bottom of the sand bed and when you turn it back on filter, it will all be blown back into the pool. If you had a multivalve, you could use the waste setting to skip the filter.
    Renting a submersible pump from Home Depot with 100 ft of hose is less than $50 for a day.
    Apr 2010
    Buckeye, AZ 85326
    619
    Also if you have a lawn or landscape plants you can use the old pool water to irrigate your plants or even a neighbors yard if they are willing. If you have an auto fill feature make sure the valve is off before you start your drain.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by mwpow3ll
    there are two small pipes going into the ground from the main return pipe from the filter before it leads into the return / waterfall junction. Anyone guess what those are? Should I close the skimmer line when draining?
    One is more than likely your aerator and the other may be another water feature like a slide slide or fountain. Turn'em on see what happens.
    I believe pool school has the proceedures you need to properly drain with your type of filter.
    Have you made the decision to step away from pucks and use liquid chlorine? It would be ashame to do all this work and spend the money on water just to get yourself in the same situation again in a couple years.
    2' Powerfall
    38,475
    Oh, forgot about the small pipes. I would be curious and just open the ball valves and see what they do ... kind of odd and pretty small so will not get too significant of flow.
    Mar 2013
    CA
    28
    deleted
    38,475
    Another random thought ... maybe the small pipes actually run as some irrigation lines? Allowing small drains to water plants? Never heard of anyone doing this, but it is possible.
    It is a mystery until you step up and turn them and report back
    Richard320's Avatar
    Jan 2010
    19,051
    UPDATE: I turned the two knobs on the two small unknown lines and water shoots out of two plastic ports, like a sprinkler fashion, from either side of the pool... is this another water feature or something else that I shouldn't be messing with?
    Those are probably to cool the water. Some people don't find swimming in bath water to be refreshing.
    I imagine they will do wonders for aeration, too, if you need to drive down TA.
  20. Back To Top    #20
    22,553
    Looks like a pretty cool fountain to me.
