Just got a new pool put in my house and my PB says that I don't need to worry about TA right now and just to focus on pH and FC. They're telling me that the TA will level itself out. I've been doing a ton of research over the past week, and I'm starting to think that the PB is incorrect and I DO need to get my TA correct now so I'm not wasting the acid that I keep adding to the pool (a couple times a week - which I hear is normal for a new pool). That being said, I'm still a noob so I figured I'd ask you guys.
Here are the current readings as of today (using my Taylor 2006 kit) -
FC - 1.5 (0 combined)
pH - 7.6-7.7
CYA - 30ish
TA - 40-50
I'm in Dallas so the temp is 60-70 outside and the pool temp is about 50-53 degrees.
Pool Details
15k in-ground pool and spa w/ dark blue pebbletec finish
Pentair DE Filter
Pentair VS+SVRS Pump
Thanks in advance for your help!
pH - 7.6-7.7
CYA - 30ish
TA - 40-50
Pool Details
Pentair DE Filter
