Results 1 to 11 of 11
Thread: New Member, New Pool, New Deck
    May 2008
    Granbury, TX
    5
    Just wanted to say Hi and to thank everyone for such a great forum. Just days ago I completed installing my deck around my new 24' x 16' ABG pool and I wanted to share them with you. I'm really blown away by the gorgeous pools on this forum and even though mine isn't going to win any awards it suits my family just fine, especially when this Texas sun heats up.
    A man's life does not consist in the abundance of his possessions. -- Luke 12:15
    Mar 2007
    Richmond, Va
    179
    Welcome aboard and very nice setup. It is amazing the pools that show up here - I have a small above ground and tiny deck, no where near as fancy as your set up, but as you say, it does the trick! Enjoy!
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    May 2008
    Granbury, TX
    5
    Thanks. It's nice to have someone validate all of your hard work. We didn't want the closed in the feeling of the deck with railing, so we are going to see how this works out. Hopefully the Hanging Plant hangers that I'm adding to the deck will prevent my drunk friends from falling off the deck.
    Jan 2008
    Jamison, PA
    110
    Very nice! Looks great. Don't knock your pool, it looks perfect from here.
    John
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome!
    Good job on that deck!
    Everything looks great!......... very inviting 8)
    We're glad you're here.
    You're done SLAMing when:
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Its a great looking pool and deck. Welcome to TFP
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Casey's Avatar
    SW PA
    10,438
    I'd definately swim in it!
    I've got some not-drunk friends who would fall off the deck... myself included
    Very nice setup! You get just as wet in a small plain pool as you do in a huge fancy one! This year I have threatened a plastic wading pool on the deck... better than nothing!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    May 2008
    Granbury, TX
    5
    Thank you for all of the kind remarks. I poked around a lot of forums before joining this one and I can say I'm ecstatic that I picked this one. Everyone is so nice and seems to truly want to help. What a breath of fresh air from the some of the other forums. THANKS
    DMAN11's Avatar
    May 2008
    Baton Rouge, LA area
    95
    bedford,,,
    Your pool and deck look great. I have a couple of questions if you don't mind. We are planning on doing our deck very similar to yours. Plan on putting the deck about have way up the pool with a small entry area even with top of pool on one side. My questions start here......how high is your deck off of the ground? Is your pool sunk at all, and if not, how high is it? Of course, how big is your deck? and it looks like you used all wood, is this correct? if so, did you consider composite decking at all and if so why did you end up going with wood.....can you share some of your factors??
    I hope this isn't going to far with the questions,,, but we are just not sure about very much in our process right now but that we know we are getting a pool. We have paid for it and it is at the pool store waiting for the installer to pick up and bring it over. So, thanks for any and all info you may want to share......
    Thanks, and it looks great!!
    DMAN
    17,500g ; 16X32 Inground Vinyl
    Hayward 1hp ; SWG
    3/4hp booster on Polaris 280
    WHO DAT!
    GEAUX TIGERS!!
    May 2008
    Granbury, TX
    5
    DMAN11,
    Ask all of the questions that you want, that's what this forum is all about. The pool is sunk in the ground on the backside of the pool opposite of the deck about 2 1/2' because my yard has about a 3' slope. The side where the deck is only about 4-6 inches below ground, so the deck height right at the pool is exactly 2' from the top of the pool. (52" pool wall buried 6"). Due to the slope of the yard, the outside edge furthest fron the pool is about 29" off of the ground. The decks length runs along the flat side of a 24'x16' oval pool and is 12'x16'. I decided to use the DekBlocks instead of building the traditional way, so I went with pressure treated lumber instead of the composite. The pressure treated 2x6's allowed me to span further than the composite deckboards, which cut down on the number of DekBlocks. I will say that I was a little skeptical going in using the DekBlocks but I'm now a believer. This deck is as solid as they come and it saved a lot of time not having to dig holes. Good Luck and feel free to ask any follow-up questions that you may have.
    Enoy your new pool.
