Thread: Low CH / Higher pH ... still OK?
    38,275
    So I am fortune enough to have great water for AZ.
    I just did a major water replacement to lower the CH and recent test shows I am at around 130 ppm in my pebble pool. The pH seems to be currently hovering around 7.8. According to poolcalc, I am sitting right around a 0 CSI
    My question:
    I am clearly low on the CH, but know it will rise due to evaporation. Is the low CH a concern if all other parameters keep the CSI in check? I just am not 100% sure if the low CH could cause problems even if the pH stays a little high.
    Test results as I remember them:
    FC 4.0
    pH 7.8
    TA 80-120 (discrepancy between old and new kit ... sounds like I am seeing the static problem with this test according to Dave)
    CH 130
    CYA 30
    Re: Low CH / Higher pH ... still OK?
    As long as you keep an eye out for the CSI level and keep it in range there is no problem running with CH at 130. We don't normally recommend doing that for a variety of reasons, but high CH fill water limits your options and makes what you are doing worth the extra effort/attention.
    38,275
    Thanks. Good to know. Just wanted to make sure I should not be running out to add calcium.
    38,275
    Hmmm ... playing with numbers and was thinking of starting to add salt soon (for feel and hopefully the SWG I have been talking about for over a year). But, that certainly hits the CSI pretty hard to the negative.
    I guess I will have to pay super extra special attention to everything as I go forward.
