Results 1 to 8 of 8
Thread: Intermatic Timer losing time
    Jan 2013
    Houston, TX
    1,079
    Just getting moved into the new house and discovered that the timer for the booster has gone kaput. Is there more than one flavor of Intermatic timer or am I good with ordering the T104M?
    Thanks!
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    38,521
    Re: Intermatic Timer losing time
    There are a few different versions depending on the voltage and use.
    If the old one was the T104 (@ 230V), then that is right part number to just replace the mechanism (assuming you are keeping the same enclosure).
    Depending on what is wrong with it, you can often replace just the timer motor and save money.
    Jan 2013
    Houston, TX
    1,079
    OK headed to the house shortly... What do I need to look at when I get there to determine part number ... or timer mechanism? I would LOVE to replace just the timer mechanism.
    As always you guys rock with the responses. Hopefully one day soon I will be able to contribute instead of just consume.
    Cheers
    Chris
    38,521
    Is the motor different than the mechanism? Maybe I have never see the motor part offered separately.
    AH, a quick Google does show just the motor ... just never saw them listed on the Intermatic website:
    https://www.google.com/search?q=replace ... atic+motor
    Jan 2013
    Houston, TX
    1,079
    Looks like sone disassembly required to figure this one out. Wish me luck!
    side note
    Any recommendations on replacement baskets? Standard round 8" (or so ... going to measure) things.
    Amazon lists the timer motors for $19 with shipping (for now anyway). You just need to make sure you get the correct operating voltage.
    Jan 2013
    Houston, TX
    1,079
    only managed to zap myself once in that process...
    found it!
    WG1573-5 208 3W
    Thanks guys - you just turned an $80 repair into a $20 repair!
