Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Wish Me Luck
    Dec 2011
    Los Angeles, California
    12
    Wish Me Luck
    So I'm just here to say a preemptive thank you for all the great information I've found here.
    We've just finished a re-model of our pool area due to the previous owners of the property laying porous slate tiles which were disintegrating and were extremely slippy.
    We replaced the whole lot with pavers and the work was finished this week.
    I've just ordered a Dolphin DX4 and I'm starting the road to taking care of the pool myself. I used to have a pool guy come in once a week, but I'm looking forward to managing everything myself. I'm a complete novice having never owned a pool before the middle of last year, so I'm still familiarizing myself with the operation of all the equipment (I had no idea which was the pump / filter etc until a few weeks ago).
    I'm going to start with the BBB method and testing will commence this week. The pool was filled from empty over the past 48 hours, so it could be an interesting process trying to balance things out!!
    30k gal IG plaster, DE Filter, WhisperFlo Pump, Pentair Heater, Jandy AquaLink PDA, Spa, Dolphin DX4 Robot
    Re: Wish Me Luck
    30,419
    Re: Wish Me Luck
    Welcome to the forum.
    It would be prudent to put a large jug of Clorox in each evening until you can post some good test results. In your climate, you are VERY susceptible to an algae outbreak very soon.
    Dec 2011
    12
    Re: Wish Me Luck
    Thanks for the tip, I raided my local Walmart for their large bleach bottles earlier today
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Wish Me Luck
    Good luck!
    LA covers a lot of ground - are you Woodland Hills, San Pedro, Eagle Rock, Tujunga?
    Dec 2011
    12
    Re: Wish Me Luck
    We're in the SF Valley.....West Hills to be precise
    Dec 2011
    12
    Re: Wish Me Luck
    So first results
    FC 1.5
    CC 2.0
    PH 8+
    TA 100
    CH 170
    CA - water stayed clear, so I assume it's low
    where to start!!!
    38,275
    Re: Wish Me Luck
    How does the water look?
    Since you are showing a high CC level, that indicates a need to go through the shock process as described in Pool School.
    You will first want to lower the pH using muriatic acid to the lower 7s.
    Then add stabilizer to get the CYA up to around 20-30ppm while maintaining the shock FC level (10ppm to start until you raise the CYA).
    Dec 2011
    12
    Re: Wish Me Luck
    Thanks....the pool actually looks OK....the water is clear (but I'm starting from scratch and it was refilled this week)
    Dec 2011
    12
    Re: Wish Me Luck
    and I made a mistake....my chlorine levels actually are;
    FC 1.5
    TC 2.0
    CC 0.5
    38,275
    Re: Wish Me Luck
    Oh, then you likely do not need the shock process. Keep the FC above 2ppm. Lower the pH and get some CYA in the pool.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Wish Me Luck
    That is actually not all that bad
    Decrease PH first to around 7.5
    Increase CYA to 30ppm and then maintain FC to around 3-4ppm
    edit: same as Jbizzle said :>)
    Dec 2011
    12
    Re: Wish Me Luck
    What about the CH....should I look to raise that also?
    38,275
    Re: Wish Me Luck
    That would be safest to raise the CH up a bit.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Dec 2011
    12
    Re: Wish Me Luck
    OK.....having some potential issues
    I've added 6 gallons of Clorox this week but can't get any Chlorine registering on the test....I added 2 gallons last night but still nothing on the test this evening. For all the chlorine tests the water stays clear.
    My PH is slightly high at 7.8 so I'm adding a little muriatic acid to get it down to approx 7.6
    TA is fine at 80
    CH is low still at 150 and I'll be adding a good chunk of calcium chloride tomorrow
    CYA test is not turning the water cloudy at all...I added a gallon of stabilizer last week and have been careful not to add too much, so I need to raise that ASAP
    Any advice would be appreciated
    38,275
    Re: Wish Me Luck
    What test kit do you have?
    Do you have the OTO chlorine test? If so, try that and report back.
    Dec 2011
    12
    Re: Wish Me Luck
    I have the DPD kit......I've managed to get the chlorine level up today to a reasonable level
    Things are looking a bit more balanced today
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Wish Me Luck
    Yes, but do you have the OTO (comparator block that is usually paired with the ph comparitor block)?
    Although the OTO test is not accurate at high levels, it is almost bulletproof in at least telling you if you have any Chlorine in the water.
    When you say you have the dpd test, do you mean the FAS-DPD test which uses a powder to turn the solution pink?
    Dec 2011
    12
    Re: Wish Me Luck
    I have the FAS-DPD Service Test Kit which uses the reagents, not powder
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Wish Me Luck
    If you do not use R-0870 powder while you are doing the test, then you are not doing the FAS-DPD test. Are you using R-001 and R-0002? If yes, then you are doing the DPD test, which in general is not very useful.
