Thread: Question to Intex pool owners who added a thru the wall skim
    Jul 2011
    Kenilworth, NJ
    12
    just a quick maintenance ? to you intex owners who added a thru the wall skimmer. where do you hook up the vaccum attachement to vaccum the pool floor. i know intex has that kit that hooks to the crappy wall hung skimmer, so if you remove the crappy skimmer for a thru the wall, how do you hook up the vaccum attcahemnt?
    thank you
    danny, form nj
    Intex 16' x 48" Ultra Frame
    Intex 2650 GPH Sand Filter
    Intex Krystal Clear Saltwater System CS8110
    May 2012
    Caledonia, MS
    123
    Re: Question to Intex pool owners who added a thru the wall
    The skimmer will come with the necessary connections. All you have to do is slide on the hose.
    I initially used the Intex hand vacuum, then purchased the Hayward auto-cleaner (I have Diver Dave), which has been great using a 1 HP pump/sand filter combo. Both attach to the thru wall skimmer without issue.
    Intex 22x52 - New 2017
    3/4 HP Doheny Pump
    16" Hayward filter
    Intex SWG
    Jan 2013
    Aruba
    229
    I used to vacuum plate adapter that came with the skimmer
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Jul 2011
    Kenilworth, NJ
    12
    thank you for the help
