Thread: Filling gunite void from the outside
    May 2012
    San Antonio, TX
    2
    I have a shotcrete pool that sits entirely above ground. There are a couple small voids/hollow spots on the outside of the pool shell. Also, water slowly seeps through one of the hollow spots. This is not causing significant water loss, just pointing out that the area is wet.
    The problem is that some critter (squirrel?) is stashing acorns in these spaces. Since water is available, the nuts are sprouting. This has me worried that it might create cracks in the shell. I've fished out this year's supply of acorns but need to cover the holes before next winter's nutfest.
    What is the best way to fill these voids?
    Thanks!
    ~20k gal IG Finest Finish-Marquise pool, Pentair Whisperflo 2HP (Dual Speed), Pentair FNSPlus 48sqft DE Filter, Legend Pool Cleaner w/ 3/4hp booster pump, 4ft Sheer Descent WF
    30,421
    Re: Filling gunite void from the outside
    Welcome to the forum. I don't see anything wrong with filling them with a grout-type material. How is the gunite finished on the outside? Would love to see a pic!
    May 2012
    San Antonio, TX
    2
    Thank you for all of the great information. I've been lurking here since before the pool was completed a year ago. It has always been maintained the TFP way (with some trichlor) and chemical balance has definitely been trouble-free.
    Most of the pool shell is hidden under a skirted cedar deck and unfinished. The exposed section (behind the water feature) has a coat of mortar mix and rises about 15 feet above ground.
    Here's a picture of the pool area:
    Here's a picture of one of the holes on the outside of the pool shell. It is just an area where the gunite didn't fill against the form boards during the build process and can hold about a dozen acorns.
    30,421
    Nice pool.
    Yeah I would suggest just getting a small bag of tile grout from home depot that comes pretty close in color to the gunite and get the gunite as dry as you can and place it in with a putty knife. If you try to do it when the gunite is seeping, It likely will wash out.
    Aug 2007
    near the swamp
    806
    repair mortar
    Since it looks like you might have a leak in that area, I'd suggest using hydraulic cement.
    http://www.quikrete.com/productlines...pCementPro.asp
    Something similar should be available at you local building supply.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
