Thread: Pump Motor End Cover
    Mar 2013
    Phoenix
    10
    Hello pool friends!
    I'm currently trying to figure out how my pump is wired so that I can purchase the correct SWG and in general know more about my pump. I have the STA-RITE 1 1/2 HP MPRA6F-148L pump but it can be wired to either 115/230V. Currently what's holding me up is that the wiring setting is shown in the end of the pump motor but is covered and I'm having trouble removing the covers. I've unscrewed it but it seems to be stuck? Or I'm just not very good at opening it. Any advise? Below is a link to the manual but it doesn't give any specific info on how to remove the motor end cover I just thought it would be good to include.
    http://www.pentairpool.com/pdfs/DynaGla ... umpsOM.pdf
    Thanks!
    12k kidney shaped inground plaster pool, single speed pump with no timer, sand filter, and barracuda scrubber guy.
    38,237
    Re: Pump Motor End Cover
    Most covers I have see are just 2 screws. Have you tried using a small screwdriver and prying on the cover a bit? It might just have a little rust holding it on.
    Sep 2012
    Noblesville, IN
    83
    Our cover is very tight. Rocking it back and forth helped a little but it was almost as if there was a vacuum holding it on.
    If it was wired correctly, you should be able to tell from the breaker if its 110 volts or 230 volts. If a single breaker controls the pump, it should be 110. If it's a double breaker, it's 230.
    Matt
    32K in ground vinyl pool installed in the early 1990s
    1.5 HP Centurion pump installed in the September of 2012, replaced under warranty in August of 2013
    2.6 SF Hayward sand filter - age unknown but looks pretty new
    Jandy AE-TI heat pump - age unknown but looks new and works great
    Caretaker in-floor cleaning system - works, but not well....on my list of things to work on.
    Aqua-rite SWG - new in about 2006, T-15 cell replaced in summer of 2012
