Results 1 to 14 of 14
Thread: I thought it was hopeless... thanks for the help!
    May 2008
    North Carolina
    6
    I just wanted to say thank you for the help that you have here.... I have been on this site a lot the last few days and am so excited about what I've learned! This is our fourth summer with our above ground 24' pool. The first and second year, everything was picture-perfect. I did whatever the pool store people told me to... it was a bit costly, but the water was perfect, so I didn't question anything. Last summer, we opened to cloudy water. Not really green, but very cloudy. Again, I continued to do whatever the pool store people told me.... purchased something different every time I went in to have my water tested. They kept telling me the levels were all good... but the water never cleared up totally. My trust was wavering.
    Last weekend we decided to take the cover off and start getting the water ready..... I'll spare you the details, but a lot of junk from the cover went in the pool. Not a good day. I thought I would never get the water clear now. Well, I started searching online wondering if maybe bleach would help before I go to the pool store to test the water. I found your site and started reading about the BBB method.... I have been adding bleach like crazy and the water is so much better! It is no longer green.... it is blue, although not clear yet... so I still have a ways to go. I just ordered the TF-100 test kit. I figure this year I'll spend the money on a thank you to your site and ordering my own test kit instead of all the chemicals the store would have told me I needed to buy.
    Thanks again! All the posts and info on this site have been so helpful!
    Michelle
    30,403
    Hi, Michelle,
    That's a very nice post....Thank you for the kit order.
    It's nice to see another Carolinian on here....there's getting to be a bunch of us.
    I hope you'll stay very active on the forum and post often with questions. It's a great bunch of people with a ton of pool knowledge.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    What a great first post... Welcome to TFP!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Michelle, sounds like you got it under control!
    Another Carolinian here
    Welcome and glad you found TFP
    You're done SLAMing when:
    May 2008
    North Carolina
    6
    Got my test kit FAST.... now I have a question....
    Wow... can't believe how fast that test kit came! I ordered it yesterday and it arrived today! Thank you!
    Here are my numbers -
    FC .5
    CC .5
    TC 1
    TA 110
    pH 6.8
    CH 250
    CYA 0
    I have added about 15 gallons of bleach the last few days. The water is now blue, but not clear. I can only see about a foot or so deep. (It also smells better.) I am seeing improvement every day.
    Now that I have these numbers, I have used the pool calculator to see what I need.... going to work on that this afternoon. Before this site, I don't ever recall hearing about CYA or Stabilizer. Last year I could not hold any chlorine.... maybe this was the problem???
    My question is about the CH test. I have an above ground 24' Zodiac pool with a vinyl liner. Do I need to add the calcium chloride? A couple of places I have read that it isn't important for the vinyl liner. Just want to make sure I am doing the right thing.
    Again, thank you so much for the info here. I have learned so much by reading other posts/questions.
    First you should bring the PH up to at least 7.0. You should use borax, though soda ash/PH Increaser will work.
    Second, you need some CYA in the pool. Long term you should aim for between 30 and 50, but don't add it all at once.
    Once you have some CYA in the water you should never let the FC level get that low. When CYA is near zero it can't really be helped.
    Your CH level is already fine. Leave it where it is.
    Once the algae is dead it can still take the filter up to a week to clear up the water. You should see a visible improvement each day.
    Fayetteville, Arkansas
    220
    Hey Michelle -
    Welcome to the forum and glad you found it. And, glad to see you are a LTS. As has been said before, there is a ton of helpful information here for just about every question you may have. So, jump in ... the water's fine!
    20x40 30,000 gal IG Liner, Pentair II Sand
    May 2008
    North Carolina
    6
    You guys are wonderful! Thanks so much for all the help. Our pool is looking great. All of the levels are good.... I love having my own test kit. Our water is very nice and blue, but still a little cloudy. I can see the bottom of the pool, but am waiting for the "crystal clear" water. Do I just need POP? Will it continue to clear up?
    Butterfly's Avatar
    South Carolina
    10,045
    You are right! There is nothing like having a great test kit!
    Yep, POP is what you need
    You're doing a great job!
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Oh gawd, not ANOTHER Carolinian!! We can't swing a dead without hitting a Carolinian anymore!! Just kidding..
    Sounds like you're almost there. Keep up the good work!
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jan 2008
    Jamison, PA
    110
    Carolinian (North) transplant here. I may have moved, but I nevert left.
    John
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Hi Michele!
    Welcome to TFP! I'm a Carolina girl at heart since I am right on the GA/SC border and spend lots of time in the low country of SC see my avatar, no place like hunting island
    This is a great site and you will learn sooooo much and everyone is so helpful!
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    May 2008
    North Carolina
    6
    Thanks for the great welcome to the site. I am actually from Texas... seems to be lots of Texans here at TFP, too! We moved to NC a little over nine years ago... we LOVE it here. But still have that Texas pride, too.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Oh gawd, not ANOTHER Texan....where's my dead cat emoticon again??
    (Just kidding again - pay me no mind.. )
    Intex 8110 SWCG
    "Fear the Schnauz!"
