Results 1 to 8 of 8
Thread: Newbie Pool owner needs help with Aqualink PDA Connection.
    Finally closed escrow on my home and among the million or two problems, I've discovered the Aqualink PDA cannot connect to the Aqualink RS system.
    I've tried changing it to ever channel, but that doesn't work. Can anyone, please recommend any other diagnostic procedures to get the PDA to communicate with the J-Box?
    Thanks a bunch!
    jkurl's Avatar
    Fairfield, ca
    141
    Re: Newbie Pool owner needs help with Aqualink PDA Connectio
    Did you change the channel on the PDA and the jbox or just the jbox or just the PDA. Jandy is very helpful w/ troubleshooting. You van try changing the batteries in the PDA and in the aqualink RS. The RS has a 9v. I have found sometimes the PDA has a tough time when the batteries are low even though the PDA might show the batteries are good. Open the jbox and see if has any LEDs lighting up. I have the PDA and it can be a bit of a pain at times.
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
    Thank you Jkurl. So I changed the 9v and I was able to proceed a little more.
    I was able to get the J-Box to communicate with the PDA to the point where I could more past the channel change screen to the next step. However, the PDA still does not allow me to proceed further than where it asks me to slide the learn switch out of "learn mode" and to hit the reset button on the J-Box.
    I can't move past that screen.
    Any advice?
    Thanks a million.
    jkurl's Avatar
    Fairfield, ca
    141
    Check the power center and make sure it is in auto and not service or time out mode.
    Can you take a picture of your aqualink RS panel so I can see what modes you have running. It could be you have either a bad jbox, power center, PDA, loose wire or loose connector. You could try shutting down the entire aqualink RS panel for about a minute to reset the power center. Sometimes chips can get stuck and cause it to lock up or put out bad signals.
    Edit: have a read of the manual. Section has some more troubleshooting tip. Sect 3.7.3 I think has how to change the channel again. http://www.inyopools.com/images/AquaLin ... nstall.pdf
    jkurl's Avatar
    Fairfield, ca
    141
    Mr. Ben,
    Just wondering if you we're able to get the PDA to connect w/ the Aqualink RS?
    Jerry
    Wow, very kind of you Jerry. Thank you for the follow up.
    Unfortunately, I have not had any luck getting it to connect. I even tried cleaning the connectors with rubbing alcohol. As soon as I get a chance, I'm going to upload some pictures.
    Thank again!
    jkurl's Avatar
    Fairfield, ca
    141
    Sounds like you at have a bad main board or the transmitter/receiver unit with the antenna. Once I see some pics of the main unit that will give me a better look at what might be possibly going on. You are welcome. Thought I would see if any of the solutions helped.
    Trace the wires from the receiver to the panel and make sure all the wires are in place and secure.
    I had the same problem.... Bought a new system and while installing, saw a wire on the old one wasn't connected.
