Results 1 to 8 of 8
Thread: New SWG to AGP
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    New SWG to AGP
    I just installed a SWG (Hayward Aqua Trol Above Ground Salt System AQ-TROL-HP) and it says to connect the bonding lug to the pool bonding system. How do you do that with an above ground pool especially a soft-sided splash pool?
    So I was thinking of driving a copper rod in the ground and attaching it to that. Or do I even need to do that?
    13x25 SplashPool (10,600 gal) AG
    20" Sand Filter with 1HP pump
    22,553
    Re: New SWG to AGP
    You really should run a #8 bare copper wire to all the metallic equipment. In your case that's probably only the pump and the swg. In order to follow the letter of the law you need to run it to at least 4 the metal legs on the pool too, but I bet 90% of those pools don't have any bonding.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    Re: New SWG to AGP
    Is there a separate grounding lug on the pump?
    22,553
    Re: New SWG to AGP
    It's a bonding lug, but yes there should be. It'll be external on the motor. Unless you have a double insulated pump.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    Re: New SWG to AGP
    Thanks, I'll have to take a closer look at my pump.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    Re: New SWG to AGP
    I looked at my pump last night and did not find a bonding lug.
    22,553
    Re: New SWG to AGP
    It may either not have one or be hidden under a plastic cover if the motor has one over it.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    Re: New SWG to AGP
    There is a little round plastic plug on the side right next to where the electrical cord comes out the end. I took it off but I could see inside. I'll check it again tonight.
