Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: shock over chlorine - indoor pool
    Hello All,
    I am a owner of an indoor pool which came with the house i just purchased. I have not owned a pool before however I am slowly getting into reading about maintaining the pool myself instead of just having someone else do it for me.
    A friend of mine suggested that I simply drop in 1 bag of shock weekly in order to keep it clean and running smoothly.
    He also has an indoor pool and this is all he does.
    Would doing this on a weekly basis be enough to keep everything OK? Or should I also be using chlorine tablets?
    I have a heater that warms the water (common?) and I have read somewhere that using a chlorine dispenser can damage the heater elements - is this true?
    Thanks all.
    fyi the pool is 20,000 gallons. The pool is fairly long but the deepest area is around 6.5 - 7ft deep only.
    22,549
    Re: shock over chlorine - indoor pool
    Welcome to TFP.
    I suggest you spend some time reading Pool School here. Suffice it to say, that throwing a bag of so called "shock" in your pool once a week isn't going to cut it.
    An indoor pool is a little different animal but the same basic maintenance is required. It's fairly easy once you learn the basics.
    A good start would be a list of all the equipment.
    thanks, i found the link to the "pool school" going through it now thanks!
    The common kinds of chlorine dispensers all use trichlor tablets, which you do not want to use indoors because they constantly add CYA and you want to keep CYA low in indoor pools. They would only damage a heater if you completely ignored your chemical levels and allowed the PH to get way to low.
    thanks, guys, any other tips would be helpful, I cannot find much information on maintaining indoor pools on the internet.
    Obviously it must be filtered and cleaned and the chemicals maintained, but this for all pools as far as I am aware. I suppose a good starting point is to run a Chemical test (I will get the strips) and see what needs to be done.
    I have just recently drained it and the company that drained it is coming tomorrow to balance the chemicals and open the pool. After this I want to take over the general maintenance of the chemicals.
    thanks
    22,549
    I would request that they not add any stabilizer (aka; CYA, cyanuric acid, conditioner, etc.). You'll need a little in the pool but it'll be much better if you add it yourself. That way you'll know how much is in there and won't have the headache of draining water again because it's too high.
    Jun 2012
    Howell, NJ
    977
    DON'T GET TEST STRIPS. If you really want to take care of the pool yourself, you need a good test kit. The only test kits we recommend are the TF-100 and K-2006, both of which can be bought from tftestkits.net.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    thanks, I was looking at the Taylor Complete FAS-DPD Pool Water Test Kit K-2006 from Amazon.com
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, pred8er
    That kit is good, though you get a little more bang for buck from the TF-100, since it includes more of the most used titrants.
    as part of the service i get tomorrow I get the following kit as per my servicers email:
    http://www.amazon.com/gp/product/B00107039U/
    Poolmaster 22260 Basic 5-Way Test Kit with Case
    I think for the short term this should do the trick?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You will benefit greatly from a better kit. Besides that kit having very low amounts of reagents (only able to do tests a few times), it appears to be missing the FAS-DPD chlorine test and the cyanuric acid (cya) test.
    I havent heard the term "reagents" since my world of warcraft days :P
    I will at least get familiar with what I am getting and how to use these testing kits- then upgrade to a better kit!
    thanks for a starting point everybody!
    Do these kits come with specific instructions - such as if some test comes in low or too high - and what is the best method to get to the correct level?
    22,549
    You can find all the recommended levels right here on this site. You'll also find all the help you need understanding how and why you need to adjust them.
    sounds good, my next stop over the next few days is the pool school!
    cheers all!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Bama beat me...
    By the way, the FAS-DPD chlorine test and the cya test will be very important right away, so I would not wait on those.
    Quote Originally Posted by pred8er
    Some do, but often times the methods they use are not what we teach here on tfp. See: http://www.troublefreepool.com/pool-...ater_chemistry and http://www.troublefreepool.com/pool-...pool_chemicals
    Aug 2010
    Dallas, TX
    4,052
    It would be interesting to know how far off your friend's balance is off because of his method.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There is a lot of good advice here, read pool school, and then read pool school again, sure it is targeted at outdoor pools, but a lot of the same stuff applies. There are a few of us here with indoor pools and we will be happy to give our advice on how managing an indoor pool is different.
    Ike
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am home from work now and can write a bit more:
    Sure you can follow your friends advice, and likely keep anything from growing in your pool, but you will likely have serious corrosion issues, the water will burn your eyes, and you will likely have a strong "chlorine" smell around the pool. A correctly balanced pool should show little or none of these effects.
    1st thing, this is a BIG one whoever you have opening your pool, make sure they do NOT add CYA at this time (it is important to have a little, but not too much CYA with an indoor pool, and the only way to remove it is through water replacement. CYA can be added 2 ways, through dry chlorine products that contain Di-Chlor or Tri-Chlor or through CYA "Stabilizer" in powder or rarely liquid form. I try to keep my CYA level at between 20-30 ppm (target is just over 20 ppm) for my indoor pool, the common test for CYA has about a 10 ppm margin of error when reading and only goes down to 20 ppm hence the fairly wide range, outdoor pools often have 40-60ppm of CYA.
    Before making specific suggestions we need to know a LOT more about your pool, what material is it made out of, what equipment do you have, etc. But until then I would say your only safe source of chlorine is liquid chlorine / liquid bleach (same thing, just strength is different) Use NO powdered bleach unless you have a plaster pool in which case a limited amount of Cal-Hypo may be appropriate if you need to increase your calcium hardness in your fill water.
    Let us know more and we can help, also DON'T trust the guys doing the opening to know what they are doing, it is very easy to end up with a BIG mess and have to drain and refill.
    Ike
    thanks I will ensure to tell them to not add CYA
  20. Back To Top    #20
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would also make sure they know CYA is added whenever you add dichlor or trichlor based chlorine "shock" products, again don't assume they know what they are doing. This is one time when micromanaging and reading the labels before they add anything could be a good thing.
