Thread: Wiring 2-speed pump for HI speed only
    Aloha guys & gals...
    Just checking in with any of you who know your electricity more confidently than I do...
    I have a Hayward 115V 1HP 2-speed pump I acquired that I am planning to use as a mobile pump for cleaning rainwater catchment tanks...only HI speed is needed, and I want to keep the switching simple (On and Off).
    The motor wiring schematic shows:
    PIN 2--Line
    PIN 3--Hi Speed Line
    PIN 4--Lo Speed Line
    I am bringing in a 3-wire, 12ga extension cord to a waterproof "ON-OFF" switch. I plan to wire nut the neutral (white) wire, and run the hot black wire (115V) through the switch, and ground to the ground screw, of course. I then plan to have the neutral (white) wire go to PIN 2, the hot black wire go to PIN 3, and the ground to the motor ground. I am completely ignoring PIN 4, since Lo speed isn't needed (and a "speed choice" switch isn't needed).
    Does this sound right to you guys?
    Aloha!
    Warren
    Big Island Pool Service
    No pool of my own...but my customers' pools are ALL my foster babies!!
    38,251
    Re: Wiring 2-speed pump for HI speed only
    Sounds right to me.
    Kind of odd though that pin 2 is called "line" and not "neutral" ... verbiage sounds more like a 230v pump.
    Was the switch already on the motor? I assume it is a spdt switch then that you will only use half of.
    Thanks Jason...
    That's what bothered me...why would they call PIN 2 Line?
    It IS a 115V motor (I have seen it running properly at both speeds)...and no, it doesn't have the switch on the back cover, or I would just leave it that way. So my extension cord goes to a watertight ON/OFF switch, and then to the motor.
    But since the old "two switches" rig was rusty and not watertight, and also since it is getting mounted to a hand-truck for mobile use, and I'm putting a 50-foot extension cord on to power it (all ultra watertight stuff), I figured I had better check with the gang here at TFP. I figure the old rig's secondary switch (AFTER the ON/OFF switch) sent the hot 115V to either PIN 3 or PIN 4 (depending upon the switch position), with the neutral going to PIN 2...but I threw the whole "two switch rig" away a year ago, so I can't check it anymore...
    Warren
    22,543
    They call it "line" because they use the same terminal board for 115 and 230 volt motors.
