Thread: A Quick Question......
    DMAN11's Avatar
    May 2008
    Baton Rouge, LA area
    95
    quick question,,,,,,
    I am really thinking about this gorilla padding stuff, but can it be used at the same time as the plastic coating my PB is using??? They put down a thin hard plastic like coating to keep grass, weeds, etc... from coming through the liner. The way I am understanding is that this gorilla padding stuff would go on top of that plastic layer, and then the liner will go on top of the gorilla padding,,,,, right??
    Anybody know of the gorilla padding first hand, is it nice to have or is Happy Bottom the only thing everybody uses??
    Thanks,,,,,DMAN
    17,500g ; 16X32 Inground Vinyl
    Hayward 1hp ; SWG
    3/4hp booster on Polaris 280
    WHO DAT!
    GEAUX TIGERS!!
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    If it can go on top of sand, I would think it could go over plastic - just a guess though.
    You might check here:
    http://www.backyardcitypools.com/vinyl- ... adding.htm
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    DMAN11's Avatar
    May 2008
    95
    Thanks Sean, I'm not sure about it now. Thanks for the link, that is the first time I've actually seen a pic of the gorilla stuff and it doesn't actually look that substantial as far as padding goes.
    What do you think?? Do you think it's worth the extra, or what do you think about the Happy Bottom stuff???
    Thanks bud,,,,,,,DMAN
    PS--- I can't wait to get our pool up on that slide show....hehe
    Hayward 1hp ; SWG
    WHO DAT!
    GEAUX TIGERS!!
    Casey's Avatar
    SW PA
    10,461
    I have the Happy Bottom pad.
    I think it gives a smoother finish to the bottom than just sand and I've had both. I'd use it again if I had to replace it/my liner which I'd hope to not replace for a very long time.
    Good luck with your pool. 8)
