Thread: pool store salinity reading is consistently about 600ppm lower
    I have a Jandy Aquapure swg that's a year old now. Runs fine and automatically tells me salinity level. The issue is that every time I go to the pool store their salinity reading is consistently about 600ppm lower than my reading. They tell me to add salt but if the Aqualink reads a salt level too high the swg will shut down. Is this happening to anyone?
    38,262
    Re: Salt level dropped from 2900ppm to 2600ppm
    The SWG is what needs to be happy, so if it thinks the salt is fine, don't sweat it.
    If it starts to read lower and lower vs the store test, that could be a sign of the cell being dirty or wearing out.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    JoshU's Avatar
    New Orleans, LA
    542
    Re: pool store salinity reading is consistently about 600ppm
    What method are they using to test the salt?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    You should test the salinity yourself and get a second test from another party. I had to adjust the salinity level for my Jandy system soon after installation. I tested it myself 3 times, using an electronic meter and test strips, as well as having it tested by two other pool companies. I then reprogrammed my Jandy for the correct level. Good luck.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
