Thread: What pressure does your DE filter run at?
    Jun 2012
    Houston, TX
    39
    I was just wondering what pressure people's DE filters run at? I'm guessing mine might be a bit high...
    Pentair FNS60 - after opening up and cleaning grids ~24 psi. After a few week it's usually at ~30 psi and backwashing only ever brings me back to ~28 psi.
    Re: What pressure does your DE filter run at?
    Filter pressure normally has way more to do with a wide variety of details of your plumbing than it has to do with the filter.
    Filter pressures around 30 are very common with in floor cleaning system, and fairly rare otherwise. Still, there is a large amount of variation from pool to pool and 30 psi is within the normal range, even if at the high end.
    If you don't have an in-floor cleaning system, you might have a valve set wrong, or some kind of plumbing blockage after the filter, or just especially long plumbing runs.
    Jun 2012
    Houston, TX
    39
    My filter system is above ground. I think it's mostly pressure loss on the long runs in my case. I'm guessing all the covers with very small holes on the returns in the pool add in some back pressure too.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    My pressure runs in the 30-35 range most of the time. But I have solar panels about 1 1/2 stories above the pool, and an in-floor cleaning system both of which add significant head pressure to the system.
    chiefwej
