Results 1 to 11 of 11
Thread: New liner & salt advise
    Apr 2011
    Elizabeth City, North Carolina
    15
    After three years and a few posts here I realize it is time to change my pool liner and while I’m at it, I’m going to add a salt water system. I have had several bids around $5000.00 for everything (ready to swim).
    It is a standard 32’ x 16’ rectangle, 6’ deep.
    I guess I’m going to stick with a local pool store because I feel more comfortable having a place of business to refer to if problems arise. I had one bid from a “does it on the side” guy that was $1000.00 less, however I have to provide my on electrician with him.
    So any advice or things to look for before I “take a plunge” ?
    18,000 gallons, vinyl IG, DE(filter area 60), 1HP Hayward
    38,301
    Re: New liner & salt advise
    What SWG are you looking at getting? Just make sure it is sized for 1.5-3 times the size of the pool so you do not have to run the pump as much and the cell will last longer.
    Add your pool details to you signature to make it easier to know what you are working with:
    pool-school/read_before_you_post
    Apr 2011
    15
    Ok~Fixed Signature with information.
    The system is a AQUA RITE TCELL 9.
    38,301
    My pool is about the same size and I will be using a T-15. The T-9 should be large enough, but may require longer pump run times which can shorten the life of the cell.
    Apr 2011
    15
    How long should you typically run the pump is the summer months?
    Seems as everyone has different answers.
    Everyone has a different answer because every pool is different, plus the common wisdom is just plain wrong on this. There is a great article in Pool School on how to figure out the ideal run time for your pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by lewis
    Did your liner only last 3 years? If yes, why?
    Apr 2011
    15
    "Did your liner only last 3 years? If yes, why?"
    No... I have lived in this house for three years, the liner is 12 years old.
    When I moved in the pool had been closed for several years. I got it straight, but last Septmeber it ripped just above the water line. So I duck taped it and closed it for the winter.
    Now I just want to start fresh with a new liner & salt system.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Makes sense, thanks for the answer.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I want to ask the pros on here if he has the correct pump and filter combination. A 1 HP pump and a 60 sq. inch DE filter? Is this a good combination for an 18,000 gallon pool?
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    38,301
    Sounds fine to me. That is basically what I have.
    We would recommend at least 48 sqft DE filter and as long as there are no high flow rate needs like spa, water features, etc, then the 1 hp is fine.
    What is your concern?
