Thread: mule team 20 and pool calculator question
    So the Borax Mule 20 is tetra on the drop down box for the pool calculator? Can I raise the borates slowly a little at a time over the weekends or do I need to do a full treatment first, I checked it with the strips and I do have zero now.
    Tf100 tests today
    Ph7.5
    FC 8
    TA 70
    CH 350
    CYA 70
    salt 3500
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    38,290
    Re: mule team 20 and pool calculator question
    I do not understand the first question. Borax is listed specifically in the calculator.
    No problem slowly adding it over time.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    30,421
    dittoing what Jason posted.....adding over time is just fine.
    Only negative side, it uses up your test strips a bit quicker, but on the positive side, I hopefully get to sell you some!!
    Sorry Jb in the drop down box in the calc it has Borax and Tetraborate, for calcs using 20 mule team I should use the Borax drop down box not the tetra one and yes Big Dave, you will be selling me lots of stuff as you personally and this site has got me now addicted to the pool, gotta make it shine!
    Yes, when using 20 Mule Team Borax you see the Borax setting on the popup.
