Results 1 to 9 of 9
Thread: Heater working but not heating
    cooper's Avatar
    Mar 2007
    Long Island, NY
    7
    I recently got a free Laars Lite 2 propane heater from a friend of mine and had my PB plumb it to my system when they installed a new filter for me. It's 125,000 btu's which I know is undersized for my 24,000 gal IGP but I figured it was free and I'd only use it occasionally to boost the temp of the pool 10-15 degrees on weekends such as the upcoming holiday weekend.
    Long story short. I fire up the heater the other day to see if it works and sure enough, it lites and appears to be doing it's thing. However, when I stick my hand in the pool by the returns the water feels like it's coming out the same temp as the surrounding water. I let it run for a good 20 minutes but no change.
    Stupid question #1: Shouldn't the water feel warmer if not hot?
    Stupid question #2: Is the heater way undersized and therefore useless and I should get rid of it?
    Stupid question #3: Did I not wait long enough for the water to cycle through and become warm?
    I think the water might be flowing through the heater too fast to heat up. If thats the case how do I slow it down?
    Thanks in advance. You guys are a great help.
    16 x 32 3'-8' depth Vinyl IG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You can't flow water too fast through a heater. The net heat flow into the pool will be the same if you heat a gallon by 1 degree or 10 gallons by 0.1 degree.
    Measure your pool water temperature. Put your vacuum hose against a return and fill a bucket with the water from the return and check that temp.
    The temperature increase can be quite small going through the heater. Even a one degree increase, which you couldn't feel, will heat significantly if you have a good flow rate. A typical heater will raise the water temperature by anywhere from one to fifteen degrees, depending on the size of the heater and the flow rate. Higher flow rates, and thus lower temperature increases, are actually slightly more efficient.
    billyjoeraybob's Avatar
    Apr 2008
    SC Midlands
    50
    I have a 250K BTU natural gas heater and when mine is running you can definitely feel warm water coming out of the returns. Might be because mine is twice the BTU's.
    Bill
    18' x 36' Freeform IG Gunite with 7' spa, Super Blue DiamondBrite, Pentair 1.5 hp circulation pump, Pentair 2.0 hp spa booster pump, Pentair Triton II Sand filter, Polaris 280 with booster pump, Pentair Intellichlor IC40 SWCG, Jandy Laars LX 250k btu NG heater, TF-100 test kit from http://www.tftestkits.com/
    Laars heaters have an internal bypass valve that adjusts depending on flow rate. Some pool water bypasses the heater and mixes with heated water so the water coming through your return lines won't feel hot.
    If the pool temperature doesn't go up at all, the bypass valve can be adjusted to increase temperature rise.
    Jul 2007
    Sahuarita, AZ
    278
    I have a 400k BTU heater and my 12,000 gallon pool heats by about 3 degrees an hour when the heater is running. Your pool is twice as large and your heater has 30% of the output. That means (using my highly complex math) I'd expect about 0.5 degrees per hour with your setup. Have you let it run for a long time and have you seen any appreciable temp change long term? Obviously this depends a lot on environmental conditions, but it should give you a WAG of what to expect.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    I also have a 250k BTU heater and can easily feel warm water at the returns when the heater is running.
    2003 Marquis Euphoria - 400gal
    Mar 2008
    Los Angeles, Ca
    222
    From wikipedia
    A BTU is defined as the amount of heat required to raise the temperature of one pound of liquid water by one degree Fahrenheit
    From answers.com
    1 gallon of water = 8.345 lbs, so 24,000 gal = 200,287 lbs of water
    So, a 125,000 btu heater will heat a 24,000 gal pool at a rate of
    0.624 degrees/hr
    I would round off to 1/2 degree/hr.
    Could just try running it for a day, and see if you get a few degrees rise.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    cooper's Avatar
    Mar 2007
    Long Island, NY
    7
    Quote Originally Posted by randytsuch
    Randy
    I think that's what I'll do. If it's insanely inefficient (which it may be) I'll just scrap it. Like I said, it was free anyway. At least now my system is plumbed for a heater so when I eventually save up for a heat pump it will be an easy install.
    Anyway, thanks for all the replies.
