Thread: Adding a lighting niche to an existing IG pool (vinyl liner)
    I already have the electrical run for an Aqualim nicheless light. Just wondering how hard and costly it would be to install a niche.
    SWG Pool Pilot Digital, In Ground pool, Surface is coral rendered. Was done in 1998.
    Pool Volume: 25,000 US Gallons, Size is roughly 15' x 30'
    Filter: Cartridge
    Pump Size: HP 1, SF 1.1
    No aerator
    Re: Adding a lighting niche to an existing IG pool (vinyl li
    Welcome to TFP!
    That depends very much on the exact situation of your pool wall and adjoining deck. To install a niche you need access to both sides of the wall. That usually means breaking out the deck in that area, which gets expensive and rarely looks as good as it did originally once put back together. If you don't have a deck in the way, or the deck is very narrow in that area and can be tunneled under it isn't nearly as bad.
