Thread: Stainless Steel Light Niche with Saltwater Chlorinator pool?
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    I noticed the pool builder is using Pentair Stainless Steel light niches for my new pool build.
    They haven't installed them yet, but I wanted to check here to see if this is a bad idea since I will have a saltwater chlorinator too.
    The part#'s are Pentair 78232500.
    Thanks!
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    Re: Stainless Steel Light Niche with Saltwater Chlorinator p
    The newer ones that are sold these days should be fine. There are many different grades of steel and nearly every pool parts manufacturer in the US has switched all their steel parts to a grade that is fine with SWG levels of salt.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Pentair said the same as Jason. Their stainless niche is perfectly fine in SWG pool.
    Just need to be sure no stray current.
    38,457
    Quote Originally Posted by prosper
    By properly bonding it!!!
