Results 1 to 11 of 11
Thread: Compupool and/or Circupool controls
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Could someone with the Compupool or Circupool let us know what the control unit displays?
    Does it display pool temp? example: 88
    Does it display salt ppm? example: 2800ppm
    We are building a 40K gallon pool, so I'd like to have a 60k gallon cell.
    Seems the options are limited to Compupool/Circupool/Intellichlor IC-60
    I wanted to get the IC-60, but I want to be able to determine salt ppm, temperature and diagnostic information.
    Thanks!
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    Re: Compupool and/or Circupool controls
    AutoPilot also makes SWGs with large cells, for example the DIG-220 with CC-15 cell, though they tend to be pricy.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Yeah, the AutoPilot looks decent. Their pricing seems to be a little out of whack though.
    We had the AquaRite with our previous pool and I really liked being able to see the salt reading and temperature on the LCD. Also the diagnostic stuff to know when the cell was heading South.
    The documentation out there on the Compupool and Circupool don't list what the LCD can actually show.
    If it doesn't show any useful readings, I might as well just get the IC-60.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I just installed a circupool in RJ60 in a 30,000 gallon inground pool.
    Yes it displays temp.
    I did not see a salt ppm measurement , just a salt ok displayed, i call up the company and the told me with the new software , if the salt gets out of bounds it will display PPM .
    And the add salt or over salt light will light.
    I bought a small pocket salt tester on ebay for 25.00 seems to be quite acurite soo far..
    The salt ppm was 480 before addind any salt so i put in 19 bags and i went to 3800 ppm .
    Took overnight ( pump running , circupool off ) and a little brushing to disolve it all.
    What they told me was whenever the add salt light comes on add a bag .
    Discount salt pools in Texas , has a sale where you get a free size upgrade
    But a RJ45 get free upgrade to a RJ60 ...saves 300 bucks !!! Or soo..
    Happy with it so far , very heaveduty unit the entire back of the unit is a heat sink !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Thanks for the info Seanhan.
    What is the vector jet for?
    I wonder what the lowest salt ppm it can be run at.
    I guess it says 3000. That's a wee bit salty for me.
    We ran our aquarite at 2800....anytime the water went to 3000+ people would talk about the salt taste.
    They didn't complain, but it was evident.
    Hrmmmm.
    The vector jet is a return fitting that causes the return jet to constantly change where it is pointed. It is a simple way to avoid having to aim the return(s) correctly, but it isn't as good as having the return(s) properly aimed in the first place (which is easy to do).
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Book says 3000 to 6000
    I did not use vector jet , i have Caretaker 99 in floor system.. All returns on on the floor ...
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I can taste the salt and mine is at 3900 now ( 3 days into conversion )
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    The salt cells for the pentair are $$ High !!!!
    I was also thinking about buying one it was in my top 2 ...
    But the penter is a very clean install .
    You can hide the power supply , since all the controls are on the cell ..
    Thats handy..
    Sean Hannon
    The CircuPool will work just fine at 2800. Higher salinity levels will yield more chlorine but your unit is wisely oversized and 2800 is all you need.
    Don Uhle, Discount Salt Pool
    Aug 2010
    Dallas, TX
    4,052
    I have the CompuPool CPSC-48 for 60,000 gallon pools. It shows pool temp and salt levels. I still trust my drops more though, but after some calibration my CPSC is pretty darn accurate. Compupool suggests 3500 ppm. I can taste salt at 1000 ppm, different people have different sensitivities.
