Thread: Replacement Rails
    Jun 2008
    Avon Park, FL
    15
    Replacement Rails
    I have a 24' pool that needs top rails replaced due to rust. I believe someone told me it was a Paradise pool. Can someone look at the picture and tell me the brand of this pool and where the rails can be purchased fairly cheap.
    15200 Gallon, Vinyl, Cartridge Filter 100 GPM, SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Replacement Rails
    I do not recognize your rails, but the corrosion does not look structural to me. If it isn't I would just remove the rust and apply some rustoleum. That is a lot cheaper then replacing.
