Thread: Fiberglass spa
    Mar 2013
    Cape May Court House, NJ
    1
    Fiberglass spa
    Size of Spa 485 gal, cartridge filter, above ground, fiberglass spa.
    Free chlorine: below 0.6
    Combined chlorine: below 0.6
    bromine: below 1.3
    PH: below 6.8
    Acid Demand: below 638
    otal alkalinity: 10 ppm
    Spa size: 485 gal
    Filter: Cartridge
    Above ground, fiberglass
    Combined Chlorine: below 0.6
    Bromine: below 103
    PH: below 6.8
    Acid Demand: below 6.8
    Total Alokalinity: 10 ppm
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Fiberglass spa
    Welcome to tfp, illingworth
    Do you have a question for us? This is a good guide to start asking a question: http://www.troublefreepool.com/pool-...efore_you_post
    Is this a bromine or chlorine sanitized tub?
    It is likely your ph is much lower than you tested and should be raised imediatly to prevent damage to equipment. I would start by raising you ph using borax and calculating how much you need using poolcalculator.com, then retest after 1/2 of circulation and recalculate the new dose and add it, repeating this process until your ph is measurable.
