Thread: Why Not?
    Why Not?
    In a predominantly trichlor/tablet based market here in Orlando, high stabilizer (100ppm +) is very common. What is the limiting factor that does not allow chlorine tablets to be made without cramming in cyanuric acid? Sorry if this is a stupid question...
    Re: Why Not?
    You have to combine the chlorine with something else that will stabilize it for transport. Very few chemicals that can fill that role are known. The only compound that is safe to transport and dissolves slowly is trichlor, which contains CYA. Cal-hypo is the closest thing to an alternative without CYA there is, but it dissolves far more quickly. In theory you could micro-encapsulate it somehow to slow is dissolving, but that would drive the price up too much to be practical.
    Re: Why Not?
    if only the laws of chemistry could be broken...
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Why Not?
    Yeah, if only. The trick is that you want the chlorine attached to a chemical where in water it will get released. There are lots of chemicals containing chlorine that remain attached and where it is in it's higher oxidation state (i.e. not as chloride), some good and some not so good -- PVC, CFC, DDT, vancomycin, etc. -- but there are far fewer where the chlorine readily releases from the chemical in water to form hypochlorous acid. There are hypochlorite chemcials that have a metal ion, including sodium hypochlorite (a liquid that breaks down faster at higher concentrations so is usually limited to around 18% concentration tops), calcium hypochlorite (a solid but is a fire hazard when more concentrated so usually limited to no more than around 73% concentration), lithium hypochlorite (a solid, but limited to around 29% concentration which is 35% available chlorine and is a much more expensive chemical), and chlorine bound to Cyanuric Acid (CYA) as either Dichlor which dissolves readily or Trichlor which dissolves slowly. And then there's pure chlorine as chlorine gas.
    Re: Why Not?
    hence the reason SWG's and liquid chlorine dispensers exist. It all adds up now
