Thread: In ground hot tub - no jet function
    Jun 2008
    Oshkosh/WI
    21
    We have an inground hot tub that is experiencing an issue.
    Everything has worked fine for years until we did some home remodeling and the electricians reconnected the spa control (on the wall outside) to the control panel at the pump.
    Now everything works but the jet (high speed) doesn't work.
    I have scoured the web for any schematics with no luck.
    I am hoping someone can help me troubleshoot this. I am an engineer and am comfortable working on this, but it is difficult when there is no reference info.
    The control panel is a Catalina RC4a
    Thanks - I am crossing my fingers that someone will help us out!
    Pool Spa Combo: 16K gallon oval inground pool / 700 gallon spa
    Pump: Pentair VS / Filter: Sand/ Heater: Pentair MasterTemp 300K BTU
    SWG: Pentair Intellichlor 40 / Controls: Pentair EasyTouch
    Other info: Equipment located in the basement
    38,364
    Re: In ground hot tub - no jet function
    Can you add some pictures of the equipment and the control panel and wiring? That may help someone here offer suggestions.
    Jun 2008
    Oshkosh/WI
    21
    I can add pics, thx for the suggestion.
    My hunch is that there is a wire not connected correctly from the outside control panel to the main control panel in the basement.
    I think this because the system worked fine until the electricians unhooked and then re-connected everything so new siding could be installed.
    What I am trying to figure out is how to 'force' or test the high-speed motor relay so I can verify the control circuitry is fine before I rip the control panel off the wall outside by the hot tub.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Why not call the electrician back out to correct?
    Factory Warranty Station for:
    Jun 2008
    Oshkosh/WI
    21
    I thought about that, but they really do not know anything about how this system functions.
    They just cut and re-spliced the cable from the outside control panel to the main control box.
    It may be worthwhile though.
