Results 1 to 11 of 11
Thread: Sad they have to drain the pool...
    Feb 2013
    Houston, TX
    50
    The guy is starting today on the work to level the concrete deck around the pool and will next be replacing the coping and tile. He was saying they would have to drain almost all the water out since they have to get into the pool to lay the new tile. Makes me feel so defeated since I just finally got it blue again! Plus we're on a well, so I'm concerned about the whole refilling aspect. Anyone have any kind words or advice to ease my mind?? Now I really wish we had the money for them to go ahead with the replaster since they have to drain the pool anyway!!
    Julie
    ~27,000 gallon 18'x36' IG concrete pool built approx. 1969
    FNSP36 Pentair DE filter w/ 1hp pump
    coping, tile, plaster redone March 2013
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Sad they have to drain the pool...
    I'm bettin' you'll have it back in top notch form before swim season kicks in easily. Hang in there!
    Apr 2012
    151
    Check your well water...use a metals kit and your regular test kit...then you will know what you are dealing with.
    Do you "refill" from the well? It shouldn't be any worse than what you have experienced previously if you are!
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Feb 2013
    Houston, TX
    50
    I guess my biggest fear with refilling with the well is running out of water! How long can you keep the water running continuously? I guess if the well pump is good enough it shouldn't ever run out. But for however long it takes to refill, we'll be turning off the pool to like takes showers or wash dishes! We did have the water tested when we bought the house and it came back no metals and the pool always gets filled with the well water, so I'm sure chemistry-wise, we'll be fine. It's just such a bummer I just worked so hard to turn it back to a pool from the brown murky pond it was!!
    Julie
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Is that taps way off in the distance?
    Do they have bulk water purchases in your area? Road construction companies and fire departments sometimes do residential sales from their bulk water licences.
    30,419
    Where I live, wells run out of water quite quickly. Your well should have a gpm rating and you should fill according to that to keep it from getting too low and sucking up dirt.
    ABSOLUTELY test your well water if you have not done so....particularly for iron content.
    Feb 2013
    Houston, TX
    50
    Well, we went ahead with the replaster! They finished up today and we're starting to refill! The pool looks AMAZING! I'm sooooooo glad we got it all done! The repair guy told us to get some Metal Out since we're refilling from a well. My husband went by Leslie's today and had them test the well water and he got the Metal Out. Here's the test results of the well water:
    FC: 0
    TC: 0
    CH: 100
    CYA: 0
    TA: 160
    pH: 7.8
    Copper: 0
    Iron: 0
    TDS: 350
    Pho: 200
    So, recommendations for what we will need to add to the pool once it gets refilled?
    Also, thought I'd post some before and after pics!
    Before:
    During:
    After:
    CAN NOT WAIT to jump in!!
    Julie
    4knights's Avatar
    NE Kansas
    419
    Call the local fire department (paid or volunteer) their pumper truck could fill you up with a donation to the fund. My local FD has filled stock tanks and pools for a donation since it gives them practice using the truck.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Swamp Thing's Avatar
    Nov 2010
    Eastern WA
    25
    Quote Originally Posted by JulieS1007
    Julie,
    Can I ask how much this part of the project cost?
    Were they builders or renovators?
    Thanks.
    In-ground Gunite 16' X 40'
    Tagelus TA/60 Sand Filter
    A.O. Smith 1 HP Motor
    Sta-Rite Dura-Glas II Pump
    Pentair #320 Inline Chlorinator
    Intermatic Mechanical Timer
    Feb 2013
    Houston, TX
    50
    Quote Originally Posted by Swamp Thing
    Julie,
    Thanks.
    Just the replaster cost just under $2700 for plain white plaster. Not sure if they were builders or renovators. We had another guy set us up with them. All I know is they were just plaster guys, didn't do any other pool work it seemed.
    Julie
    Nov 2010
    Eastern WA
    25
    Thanx Julie
