Thread: Question for my personal pool....
    Apr 2012
    151
    I am about to replace the liner in my personal pool. That is easy enough, but my conundrum is this:
    Since I bought this house (with the pool), the "light" (use the term loosely) has not functioned. I hate it. It is a Pentair Aqualumin 2 (It may be a 1). Immediately I replaced the bulb, and that worked for 2 weeks, and then the seal around the lens failed, allowing water into the internals of the light. Needless to say, the light is now garbage, as I can only get a replacement for the whole light, and not just the rear, metal parts that I need (they are corroded).
    I would rather not replace the light with the Aqualumin 3 due to this experience and the experience of some of my clients with this same light. This is a nicheless design light, so my options are, well, none.
    I have come across the Savi Buddy light that only requires a 1.5" threaded retrun to install. I have talked to tech support at Savi, but they had no experience replacing an Aqualumin with the Buddy.
    My question is:
    Is there a way to retrofit a 1.5" return into the pool wall through the liner (while it is out) so that it meets up with my conduit so that I can install this light for the Aqulumin light?
    No one seems to have tried this before. I do not want to bust up concrete to get behind the wall, so a regular, compression wall fitting will not work. There has to be a product out there to get this done, I just don't know about it!
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Nov 2011
    Moberly,MO
    1,010
    Re: Question for my personal pool....
    You will have to dig up behind the wall even to put a savi light in your pool. They are water "cooled" and will have to be plumbed above the water level in the pool or you will have a leak.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2012
    151
    How can I plumb it above the water level, and still water cool it? Literature says that it needs 4" minimum BELOW the water line...
    Nov 2011
    Moberly,MO
    1,010
    Light needs 4" below water, conduit has to end above water so it won't leak.
    Apr 2012
    151
    The conduit is there. There is a junction box in my diving board stand. I just need to know if there is a way to add a 1.5" return fitting without digging up behind the wall.
    Nov 2011
    Moberly,MO
    1,010
    No you will have to dig behind the wall to put in a water tight conduit to above water line from the wall fitting
