I have been upgrading my load center to automation. Thank for all for your help here.
Original load center pro installed had a bonding wire attached to the loadcenter ground bus. It is my understanding that this is not necessary, but permissible. Bond could have gone to the outside shell only.
In repairing broken pvc to my pool light conduit I noted the 120v pool light comes to the above ground box with a hot, neutral and ground, but no bonding wire in the same conduit to the above groud (J? BOX). It then routes to a switched gfci in my home. I believe the below water light niche is brass. I must assume that the bonding wire to my panel bonds the pool and hopefully the light niche as well even though it is not going through the light cord conduit.
Can anyone recommend a way to test if the underwater niche is bonded to my bonding wire with out digging up behind it? If the light has a gfci is the code alone?
Thanks.
Thanks.
