Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Fiberglass pool under construction near San Antonio TX
    Jan 2013
    Texas
    39
    I'm hoping to use this message board as basically a blog of my pool install so here goes.
    Here is my backyard before the pool. I had to have the deck stairs reconfigured to make more room for the pool:
    Pool Build in Progress: 29' kidney bean shaped fiberglass pool, Tuscany model from Leisure Pools, 12400 gallons, 1 1/2 HP Pentair Whisperflo pump, Pentair Intelliflo Salt System 40, 200 square feet Pentair cartridge filter, 1 skimmer w/ 3 returns, LED lighting, Belgard Mega-Arbel pavers.
    Jan 2013
    Texas
    39
    Re: Fiberglass pool under construction near San Antonio TX
    I was super excited when the excavator arrived on the weekend before my build was to start. The official build start date was March 18th!
    Jan 2013
    Texas
    39
    Here is the original pool design:
    Jan 2013
    Texas
    39
    Construction started on 3/18, but the builder found out that there was an issue with the original location of the pool so it had to be moved. Here is the pool template laid out in the backyard in the final location.
    Jan 2013
    Texas
    39
    Here is the revised design. Although I wasn't thrilled to spend the extra cash which put us over budget, my wife was happy to have the extra decking so I think it will be worth it.
    Jan 2013
    Texas
    39
    Digging started on 3/20. I was super excited. Note the irrigation line that is being dug up. Thankfully, that would be the only one and it looks to be relatively easy to reroute the irrigation around the pool to the sprinkers along the back fence.
    Jan 2013
    Texas
    39
    Here is the progress at the end of the day 3/20.
    Jan 2013
    Texas
    39
    There was a lot of activity on today, 3/21. They started the concrete pad for the pump and they hauled in the crushed/washed limestone. Also, they continued digging and I believe they are almost done. Thankfully, they never did hit rock!
    Missouri City, TX
    73
    Looks good. I think you will find that you will be glad to have the extra deck space.
    20,000 IG WetEdge Satin Matrix Northshore Plum, Filled 8/24/12
    I agree the extra deck space will be nice and less grass to mow in a confined area!
    John Nguyen, CWS I
    Sales and Applications Engineer
    Stenner Pump Company
    Jan 2013
    Texas
    39
    Quote Originally Posted by blakestretch
    Yes, the more I think about it, the more I realize its the right way to go, its just hard to see things go over budget considering that I already had to raise my "budget" 33% in the first place
    Today should be an exciting day, I am hoping that the crane will be here to lift the pool shell over the house. Its kind of misty out today so I hope nothing happens to delay the work.
    Here are a couple pictures of what the front yard looks like now after a few dozen trips back and forth with the Bobcat:
    Jan 2013
    Texas
    39
    The pool has arrived! But it was not without some drama. They delivered the wrong pool at first. It was the wrong gelcoat color, sapphire blue instead of crystal blue, but the right one is here and ready to go!
    Also, I found out that there was a snafu with the crane so we won't have one today. Instead, they are going to carry the pool like a briefcase between the houses. Sounds almost as precarious as dangling the pool over the house so I will definitely have pics of the process.
    Jan 2013
    Texas
    39
    Okay, I think you're going to enjoy this. They are going to try and carry the pool into the back yard using the excavator, the only problem is there is only about 10 ft clearance between my house and my neighbors, lets see how it goes...
    Here is the hole with the crushed limestone base.
    Here comes the excavator to retrieve the pool... note how tight the fit is without having to carry a 29' pool.
    Got the pool and headed to the back yard.
    Its a tight fit!
    Here is the view from the other side.
    Looks like they're going to make it through!
    My neighbors were a little surprised at their new above ground pool
    Okay, time to get the pool into MY backyard
    Almost there...
    Done! Kudos to my installer, that was amazing... the whole neighborhood was there in case something went awry, but Chandler pulled it off without a hitch!
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Great progress!!! Can't wait to see more pics!!!
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Jan 2013
    Texas
    39
    Quote Originally Posted by Killer95Stang
    Thanks, I am happy with the progress and excited to see what they are able to get done tomorrow.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Its ALWAYS good to have more decking! One can then move loungers around the pool ad lib, following or avoiding the sun as the day progresses. It also helps keep grass clippings out of the pool as you mow.
    Nice to see another fiberglass pool go in. We love ours!
    Wow! that was some fancy manuerving! amazing how they can do that. My dad has a fiberglass pool and it has lasted for years and is wonderful. I hope you like it. We are building gunite just so we can customize it to exactly how we want it, otherwise, FG would have been our option. So exciting! KIM
    Jan 2013
    Texas
    39
    Quote Originally Posted by Texgirl
    I was really impressed with the skill of my installer to fit that pool through there! That's good to hear about your Dad's pool is holding up well. I have a lot of confidence in this company so I think it will be great in the end. Our yard is so small that most of the customization will be done on the decking and retaining wall options. In fact, we are still discussing exactly which materials to use. We are looking at pavers as well as travertine. Perhaps pavers for the decking and retaining wall with travertine coping and wall caps, but we shall see. I think I'm pushing the builder a little beyond what they have typically been doing, but they seem to be open to expanding into some new design areas.
    Jan 2013
    Texas
    39
    Here is the progress from Saturday. They have started filling in the limestone/gravel around the sides and also filling the pool at the same time. Also, they have installed the skimmer and the returns.
  20. Back To Top    #20
    Apr 2012
    Bonner Springs, Kansas
    109
    So did the guy in the excavator have a special made seat in the cab to accommodate his extra large testicular girth? Seriously though, how in the world did you stomach watching them bring that through the space - much less take photos! it looks great in the space, a perfect fit for your space! Keep the photos coming - it looks like you're going to have a great looking oasis!
    You mentioned you may be going overbudget, does cutting the crane out of the bill help?
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
