Results 1 to 12 of 12
Thread: Liner fit issue
    Liner fit issue
    I'm new to liner replacement and just had a contractor replace mine which is rectangle shaped. I'm not sure what radius corners he specified to the liner company, but one corner has a good fit, but the other three are taut across the corner with about a 6" x 6" x 12" triangular space from the ground up to about a foot form the top. The pool is filled up and the top of the liner is staying in the coping at the corners. The temperature is in the 40's here in Virginia. The contractor is saying after the temperature warms the liner will relax and seat properly in each corner. Right now, it just looks like the liner doesn't fit correctly. My first thought is, that he could drain the pool down and heat stretch the liner in the corners. Does anyone have experience with this? Does anyone know if liners relax this much over a 30+ degree change in temperature?
    36,000 Gallon Concrete/Vinyl Lined In-Ground/Indoor
    Sta-Rite T-240bp Sand Filter/Pump
    Atmospheric 130A Heater
    Taylor K-2006
    In Michigan's Great Southwest!
    30,395
    Re: Liner fit issue
    Welcome to the forum. A pic would help but it sounds like your liner will not fit. If it is 3-5"" off the wall in the corner (s), I don't think warm weather will help. The water pressure would press a correct liner tight to the wall everywhere, regardless of temp.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Liner fit issue
    Is it even a good idea to install when the temp is that cold? I'm no expert, of course, but it seems like it would be better to do it in warmer temperatures.
    Re: Liner fit issue
    The day the liner was installed, the temperatures were in the 60's. Now after the pool has been filled up, the temperature dropped into the 30/40's.
    Taylor K-2006
    30,395
    Re: Liner fit issue
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Liner fit issue
    Yeah, it doesn't fit. They need to get you one that does.
    Re: Liner fit issue
    Here's one corner. [attachment=0:iyz294td]DSC04105 - Copy.JPG[/attachment:iyz294td]
    Taylor K-2006
    Nov 2011
    Moberly,MO
    1,010
    Re: Liner fit issue
    That is a 6" radius corner and that is somewhat the natute of the beast. We won't build a pool with aything shorter than a 2' radius corner since it will lay tight to the wall.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    30,395
    Re: Liner fit issue
    YOur description of forming a triangle 6x6x12 off the wall is hard to find in the picture.
    In fact, It's hard to tell it is off the wall at all. Do you have a pic that would better demonstrate what you are talking about?
    Re: Liner fit issue
    I don't have a better picture. There's about 3 or 4 inche gap between the stretched liner and the hard wall behind it in three of the corners (not a perfect triangle, as you can see). If this is truly the nature of fitting a liner to a 6" radius corner, then my next concern is this going to affect how long the liner lasts. Obviously this could get punctured more easily with a void behind it. The previous liner eventually ripped in one of the corners (only 5 yr old). On another note, does heat stretching lead to rips and tears eventually?
    Taylor K-2006
    30,395
    Re: Liner fit issue
    Yeah, even though it may not show up in a pic, 3-4 inches off the wall is CLEARLY a liner that doesn't fit and I would ask that it be replaced.
    My corners have an 18" radius and they fit tight to the wall like a glove. Yours should to. It is not the nature of the beast and will have long term negative effects.....like the liner pulling out of the track.
    Nov 2011
    Moberly,MO
    1,010
    Re: Liner fit issue
    We have been building vinyl liner pools for 30 plus years. Hate to break it to you duraleigh but a 6" corner usually will not lay flat to the wall the way vinyl liners are made just does not make them fit. We custom fit every liner we install and I have yet to see a 6" liner work.
