Thread: Impressive pool popping
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Don't drain your pool when the groundwater is high!!
    http://www.tucsonnewsnow.com/story/2134 ... -of-ground
    38,371
    Re: Impressive pool popping
    I was about to be shocked seeing that it was a Tucson News story ... wondering where it could have happened around here.
    Now I see it was GA ...
    Casey's Avatar
    SW PA
    10,450
    Wow!
    Oct 2007
    Cedar Hill, TN
    252
    Good luck with the insurance!
    I don't think they are responsible for homeowners ignorance.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Apr 2012
    Bonner Springs, Kansas
    109
    I guess that's a "don't drain your pool when the groundwater is high" unless you want to go the rapid removal method. Pool extraction by mother nature. Water pressure always wins!
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    always amazed at the number of pool owners that think draining a pool is a good idea when they have a major pool clean up on their hands. I live in houston so I wouldn't even consider doing that.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
