Thread: Plaster and Temp
    GTGallop's Avatar
    Aug 2008
    Cave Creek, AZ
    39
    Plaster and Temp
    Our pool is 16ish years old and will need plaster in the next 2 or three years. Our plaster is your standard white variety - nothing fancy. But my inlaws (that live very close and have the same exposure we do) have a dark pebble-tec in their pool. Their pool always runs about 10 degrees warmer than ours does. This means they open sooner and close later.\
    Does the color of the pool coating make that much difference? We are in Phoenix and I already get 6 to 7 months a year out of the pool, but if I could get 9 that would be great. Might circumvent the need for solar heat.
    3rd Time Pool Owner - 2014 In Ground, Gunite/Pebbel-Tec, 24' long 10,000 Gallon, Chlorine, 2 Hp Hayward Ecostar with Cartridge.
    http://www.troublefreepool.com/my-on...le-t40734.html
    Cave Creek, Arizona
    38,532
    Re: Plaster and Temp
    If the only difference between the pools is the color, then you have your answer But, there could be other things at work, like your may be more exposed to winds that would cause fast evaporation and cooling, for example. Do they use a cover and you do not?
    I think the dark colors can help, 10 degrees seems surprising to be though. The cheapest thing to try would be to use a cover at night to retain the heat gained in the day.
