Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Tee Shaped pool in Alabama * UPDATED PICS 4/21/13
    We have rain forecasted for tomorrow and possibly snow flurries for Friday...So cross your fingers that the weatherman is wrong and that the pb will get lots of beautiful and dry days to work on my pool.
    I'll post pics as it progresses. This first pic was taken after we removed the privacy fence and had lots & lots of trees cut down. There's a lot of work to be done on the ground before the pb can even start the pool.
    26 x 37 x 8 Tee Shaped Pool / Mayan Liner w/ Sandstone colored bottom[/color]
    Hayward Max Flo vs pump
    SwimClear Hayward C3030 Cartridge Filter
    Aqua Logic 15T Salt Generator
    2 Hayward Universal Color Logic Lights (12 volt transformer)
    12 Volt Dolphin M-4 Cleaner
    6 Foot Diving Board
    22,553
    Re: New pool build in Alabama
    You must be one of them yankee Alabamians! It's supposed to rain down here but I don't want to hear nuthin bout no snow!
    That's a big pool if my guess is correct. If I'm right, the filter and swg is going to be too small. How many gallons is it supposed to be?
    Re: Pool under construction in Alabama
    Yes, I'm in North Alabama but cannot believe there is a possibility of snow!!! Could be as much as 2" but it should be very short lived, thankfully. Weather in my area is so interesting...it was upper 70's & sunny over the weekend and this weekend it will be in the 30's/40's...
    As far as the filter goes...after posting a thread about my pool specs, I got feedback that my filter was too small so I spoke with my pb and he agreed and we are going with a larger sand filter. We had originally decided on a smaller pool but after signing the contract went with a larger one and so the filter info I had was from the smaller pool. However, you're the first person to mention the pump being too small. Should I consult with my pb about going with a larger one?
    6 Foot Diving Board
    22,553
    You don't state what size the pump actually is and you didn't in the other thread either. I'm sorry I missed it before but the Max-Flo isn't a variable speed pump. You need to find out exactly which pump you're getting.
    I went back and looked and if you're getting the T-Cell-15, it'll be plenty big enough.
    Looking thru the paperwork... it says Max-Flo VS, variable-speed pump.
    6 Foot Diving Board
    Looked a little further and the swg is an Aqua logic 15T. Is that the same as a t cell 15?
    6 Foot Diving Board
    22,553
    That should be the T-Cell-15 so you're good there.
    I just went back and looked and they do make a Max-Flo VS so that's good too.
    As long as you're getting a larger filter everything should be fine.
    Great! Thanks so much for your input
    6 Foot Diving Board
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Curious...
    Do you know your planned pool volume (I ask since I am not sure how to figure out your volume from the dimensions you gave)?
    What filter size are you now planning on getting?
    I've figured it at about 31k/32k gallons...not sure about the filter size but know that its bigger. I'll find out & post it. Thanks!
    6 Foot Diving Board
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by myoung36
    That will be a big pool. For your ~31000 gallon pool we would recommend a minimum of 5.8 sq. ft (33" diameter) sand filter, or minimum 560 sq. ft. cartridge, or minimum 86 sq. ft DE filter.
    Re: Pool under construction in Alabama FINIALLY DIGGING!! Wh
    After a very wet and cold several weeks, our pool build has finally started!
    Day 1 was spent prepping the yard for the pool. There was lots of leveling to be done.
    Day 2, the pb laid out/painted the pool design on the ground and started digging...at the end of day 2 I had a shallow end Hopefully tomorrow will be dry again and he'll get the rest of the pool dug out.
    FYI...for those who have brought the filter size to my attention, I am going with a cartridge filter now that will be plenty big enough for this size pool. Thanks again to everyone that brought that to my attention!
    So, here's some pics from the first 2 days.. Nothing too exciting for most people but for me it awesome!! As you can see in the pics, my girls are quite excited too!
    6 Foot Diving Board
    DAY 3
    PB got the shallow end dug out and also the slope going into the deep end. Just a little more digging and we'll be ready to move to the next step of the build. Rain is in the forecast
    DAY 4
    Well, weatherman was right...unfortunately! The rains came and the pool filled up PB says he'll have to pump the water out. We are supposed to have about 3 days of sun then rain moving back in. SOOOOOO discouraging. I'm beginning to think this pool will never get finished!!
    6 Foot Diving Board
    4knights's Avatar
    NE Kansas
    419
    The rainwater will go away and you'll be swimming in no time. I noticed on your first picture the side of the house where you are putting the pool looks like a great place to add a pergola or covered outdoor kitchen. Keep posting pictures
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Thanks for the encouraging words. The pb pumped the water out yesterday so hopefully in another day or two the ground will be dry enough for them to start digging again. Of course there is rain in the forecast for tomorrow
    @4Knights, I agree, a pergola would be great on the side of the house!
    6 Foot Diving Board
    Pool under construction in Alabama UPDATED PICS 4/8/13
    After a 10 day break in the build due to flooding rains, the build is back on!!
    Day 4 they finished digging the pool and got the walls put into the pool. Tomorrow they will be putting the walls in place and putting concrete in. By the end of Tuesday it should start resembling a pool!!
    I apologize for the pics not being very good but I didn't get home until late last night and so I headed out early this morning to get my pics and was caught, by the pb, taking pool pics in my jammies HOW EMBARRASSING! The ONE day he shows up before 7am and I'm out there...
    So excited about the new pool....I'm getting the margarita maker ready for pool season as I type
    6 Foot Diving Board
    4knights's Avatar
    NE Kansas
    419
    Re: Pool under construction in Alabama * UPDATED PICS 4/9/13
    He may have caught you in your Jammie's but he could have caught you in nothing. Had some unexpected company one evening when we wee in the Hottub. Good thing for the bubbles
    Day 5 of the pool build...
    PB put the walls and supports in and poured the concrete around the base of the walls. Starting the plumbing tomorrow! It's starting to look like a pool!! I better reread pool school so that I'll be ready once the pool gets finished
    6 Foot Diving Board
    Another view of the pool after day 5 of the build.
    6 Foot Diving Board
  20. Back To Top    #20
    Re: Pool under construction in Alabama * UPDATED PICS 4/10/1
    Day 6 of the pool build...
    PB got all the plumbing in and both the lights as well as got the pump and filter set up. Forecast is calling for torrential rains tomorrow so the pb put a tarp over the pool to keep the bottom dry. He's ready to put the Pool Krete in. PB said he'll need 4 dry days to get the Pool Krete finished and the liner in..Crossing my fingers that the rain misses us..
    6 Foot Diving Board
