Thread: Phosphates/Nitrates and Pentair IntelliChlor
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    I have been reading through several posts regarding phosphates and nitrates and most say to ignore; however, the IntelliChlor manual has this info:
    Nitrates and Phosphates can cause extremely high chlorine demands and will deplete chlorine from
    your swimming pool. In some cases nitrates may even lower your chlorine levels to zero. Your local
    pool professional can test for nitrates and phosphates. While a 0 ppm level of nitrates is the ideal, the
    pool owner should make sure that nitrates DO NOT exceed 10 ppm. Phosphates should not exceed
    125 parts per billion (ppb
    So should I be concerned about these presence of these in my water or not? BTW, I haven't tested to see if they are present in our water; I am just trying to read through manuals/pool school/posts, etc before we actually fill our pool so that we can have a handle on it when we do.
    Thanks for all the help.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Re: Phosphates/Nitrates and Pentair IntelliChlor
    Just ignore them. Many many people on the forum have levels way above that and no problems at all.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Thanks. That is what I have been reading but wanted to be sure I was following manufacturers recommendations as well. Looking forward to a "troublefree pool"!
