Thread: water test results = Are they ok?
    Jul 2012
    AZ
    9
    I am a little skeptical when i get my local chandler.az Leslie's to test my water so I know i need to get a better test kit that you guys recommend and leave them out of the picture. Below are my results, do you think I am in balance {yes i know when i get home to add acid, Ph is to high] As you know Az water is extremely hard. i dumped and refilled in 9/10. Can I maintain and keep my pool balanced this summer with the info provided? CYA seems out of line, late last fall it was around 60-70. CH is high?, the Leslie guy said it would come down when the Ph is adjusted?I have a Myron L micromhos meter that reads my water at 7000 which converted to TDS using a .067 constant equates to 4690 TDS, i read that TDS does not mean anything in pool water balance, is that correct? i was always under the assumption that when your incoming water concentrates in the pool 2-3 times its time to dump and refill the pool? I need to read more at pool school and learn the water treatment a lot better...thanks in advance
    fc=3
    tac=3
    salt=3300
    ch=760
    cya=165
    ta=109
    ph=8.3
    copper=0
    iron=0
    temp=60-65f
    15k. ig 16yrs old pebbletec pool, pacfab 150sqF cartridge filter, circupool rj30 SWG. 1.5hp challenger pump hayward pool vac XL
    Aug 2010
    Dallas, TX
    4,052
    Re: water test results = Are they ok?
    I doubt their CYA test is correct. Get your own test kit and you'll have a better idea.
    You need to get TA down. You'll lower the pH during that, it shouldn't be up that high. Once you get TA down, you will have less trouble with pH.
    pool-school/lowering%20total%20alkalinity
    38,290
    I think you actually are heading in the right direction (and realize it). Read more Pool School and order yourself one of the recommended test kits.
    Hard to give advice based on the questionable results for a pool store.
    Jun 2011
    Long Beach, CA
    2,788
    Pool stores are notoriously wrong on the CYA, but depending on your chlorine source, it might be way above 100 and it is time to change the water. The water change will also help with the high CH.
    Take the advice above, read Pool School, and do yourself a favor, get one of the recommended test kits TF100 or K-2006 on-line. Testing is easy after a couple of times, and your test kit will be much more reliable than the pool store.
    Jul 2012
    AZ
    9
    So lets say the pool store readings are correct, time to dump and refill? or fight the battle, lots can go wrong fast out here with the 100+* heat days and the monsoon load on the pool. Have a test kit in my cart just not quite sure about which one to get k 2006 or the tf 100.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Zona
    If they are correct, yes, you need to get your cya level down.
    I would get the tf-100 (more bang for buck than the k2006). I would also wait to do anything until you kit comes and you know for sure what your cya is.
