Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: CYA - seems to cloud water?
    Jun 2012
    Lafayette, Ca / USA
    260
    OK, after a total refill of our newly reconstructed (Fiberglass lined over gunite) pool, I have been woring at getting my CYA up close to 50. A side effect that I am noting is that as the CYA levels increase, my pool appears more cloudy ... or basically just not as crystal clear (sparkly?) as pure water with lower CYA levels.
    I assume this is normal? Is there a recommended additive of some sort that gets things "sparkly" clear again? or is such additives not recommended?
    my figures (am slowly adjusting as temps are slowly warming up):
    water temp = 62
    CL = 5.0
    CH = 210
    TA = 80
    PH = 7.5
    CYA = 40
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Aug 2010
    Dallas, TX
    4,052
    Re: CYA - seems to cloud water?
    Adding CYA has never made my water cloudy, less clear, or less sparkling.
    Jun 2012
    Lafayette, Ca / USA
    260
    OK, then bear with.. When I "test" my CYA levels using the TFT Kit, I mix 50% regeant with 50% water .. then start filling my test tube until "I can no longer see the black dot at the bottom ... That is CLOUDY thereby obsucring the black dot .. with clear water, well, obvioulsly you see the black dot no matter how much water is added to the tube. So I guess when I say "cloudy" water, it is just not 'sparkly' clear like with no CYA conditioner added ... I mean I can still see the bottom & the drain ports etc .. it's not like I can't see the bottom or anything - but just notably not "sparkly" like water was w/o the CYA added. thanks.
    Aug 2010
    Dallas, TX
    4,052
    The water turning cloudy while performing the test is how the test works. I'm a little confused.
    When you are doing the CYA test you specifically add a chemical (the test reagent) that is designed to cause the water to turn cloudy when CYA is present.
    You should not be seeing anything similar to that cloudiness in your pool, regardless of CYA additions. If your water is less than sparkling clear, something is going wrong, possibly minor, possibly major, but worth investigating in either case.
    Jun 2012
    Lafayette, Ca / USA
    260
    my point is that w/o any CYA in the pool at all, the regeant testing solution is obviolusly CLEAR - sparkly clear - as is the pool water ... As I've been slowly adding CYA over the last 6 weeks, that test now becomes CLOUDY in the tube as you fill it - to obscure the black dot ... and I just perceive a similar observation with the pool water ... it is no longer sparkly clear as when CYA was yet added to the water ... but again, not totally CLOUDY .. still looks great ... just no longer 'sparkly' clear. - most noticeable to me in the deep end looking at the drain.
    38,295
    Sounds like something may be trying to start grow in the pool if it is becoming cloudy.
    Raise the FC up to shock level and perform the OCLT to see if that tells you anything.
    30,421
    Any cloudiness in your pool is totally unrelated to the addition of CYA.
    The solution in the CYA test becomes cloudy only when you add the R-0013 reagent.....there is no R-0013 in your pool.
    Jun 2012
    Lafayette, Ca / USA
    260
    OK ... thanks all ..
    Smykowski's Avatar
    Sep 2011
    3,065
    As you're adding CYA, are you adjusting your minimum FC value upward?
    Jun 2012
    Lafayette, Ca / USA
    260
    Yes.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You listed CL above. Do you have measurements for FC (Free chlorine) and CC (combined chlorine)?
    Jun 2012
    Lafayette, Ca / USA
    260
    I have 1 that is a week old .. Let me get a fresh reading in the next couple of days after my recent additon of CYA "settles". Thanks
    Smykowski's Avatar
    Sep 2011
    3,065
    Get a new FC reading now. In terms of testing, one won't affect the other. Any recent CYA addition could take a few days to a week to show up on the test.
    Based on what I've read so far, my guess is that your FC level is still too low for the new CYA level. I would try maintaining an FC level 2-3ppm higher than what you were and see if that helps.
    Jun 2012
    Lafayette, Ca / USA
    260
    OK, will do ... and report back. Thanks !!
    Jun 2012
    Lafayette, Ca / USA
    260
    Hi guys .. OK, I finally got around to getting the results from my test yesterday. Results:
    FC = 4.0 (after this, I added 82 oz of 8.25% bleach)
    CC = 0
    TA = 90
    CYA = 50 (I finally got this up to 50 - had been 35-40 over last week)
    CH = 220
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Your test numbers look good (and you addition of chlorine should bring you up to ~6 ppm)...how does your water look?
    Jun 2012
    Lafayette, Ca / USA
    260
    Looks decent ... again, just not "sparkly" like it did prior to adding CYA (clear & fresh tap water). Just an observation ... Everyone says it looks great - just my own 'eye' I guess.
    Thanks ...
    So after the pool was filled it was sparkly. Then you started adding cya and running the pump it got a little bit cloudier? You may want to clean and inspect your cartridges
  20. Back To Top    #20
    Jun 2012
    Lafayette, Ca / USA
    260
    OK, thanks .. will do ... and we can close this thread ..
