Results 1 to 8 of 8
Thread: LED question.
    LED question.
    We are currently on our second pool build. The gunite is in and we are waiting for tile to be installed this week. The first pool we did had a traditional pool light so the LED is new to us. That being said our neighbor is also in the middle of a pool build, only about a week ahead of us. They also are getting LED lighting. They're fixture looks just like it would for a traditional light, as far as size and placement. Where our lights are going there is just a PVC pipe, and they are high up, where they will be just under the waterline tile. Just wondering if anyone had seen anything like this before.
    I'm going to ask the PB about it today, I just wanted to get some feedback here as well.
    Is it possible they are using the shallow water lighting as our regular pool lighting?
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: LED question.
    Not sure about placement, but I do know that the LED fixtures give off less light overall than incandescent bulbs. That is why we chose to use two LED fixtures in our build over just putting one traditional light. We also went with a full sized LED fixture in the spa, rather than the smaller Spa LED fixture.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Re: LED question.
    Just talked to PB. He said they are using the Pentair Glo Brite LEDs. Which are the smaller shallow water/spa versions. He said they use two of these versus one full sized, because it lights the entire pool this way.
    Re: LED question.
    The GloBrite lights are fairly new and about 1/3 as bright as the larger IntelliBrite lights. They are much easier to install, which has raised their popularity with builders significantly above what you might expect for a new product.
    Re: LED question.
    Interesting. As long as it lights up the whole pool I don't mind. It's only a 28x14, 3-6' deep freeform pool, so hopefully it will get the job done.
    4knights's Avatar
    NE Kansas
    419
    Re: LED question.
    I have the Savi melody lights, they are 5 color LED and are installed in a standard return fitting. The back side of the fitting has a 14inch piece of straight CPVC conduit then a CPVC 90 degree bend then CPVC run to the transformer. These can be mounted as shallow as 4 inches below the waterline.
    We like the look and 2 light up the pool very nicely.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Re: LED question.
    That's good to hear, thank you! We're using a very reputable PB and we are trying to trust them and not ask a lot of questions. It's difficult because we did not have a pleasant experience with our first pool build with a different PB.
    4knights's Avatar
    NE Kansas
    419
    Re: LED question.
    I would think that with as much money you spend having it installed all the questions you ask should be answered no problems, some even answered twice.
