Thread: EasyTouch Mounting
    Feb 2013
    Metro St. Louis
    93
    EasyTouch Mounting
    Getting ready to have an EasyTouch 8 installed on the side of our house. PB indicated he could fasten to our vinyl siding or put on a separate post next to the house. Was leaning towards having it directly on the house for maximum stability and protection from the elements (roof overhang helps).
    However, I am thinking it will "mash" my vinyl siding if bolted tight to the house. Found these spacers (attached images) for use by awning systems, but think they would work great for an EasyTouch.
    Anyone have an easier/cheaper solution?
    Paul
    Sterling Steel IGP lagoon 21' x 35' w/6' deep end, Pentair 5g LED lights (x2), Pentair Landscape LED light, Pentiar IntelliFlo VS pump, Pentair 420 Cartridge filter, Pentair IC20, 4 gas Tiki Torches, LoopLoc Ultra Loc II, Deck Jets(x3), Raised Planter Bed with 3 Pentair bronze sheer decents, AquaBot Breeze 4WD, Pentair Legend II
    Re: EasyTouch Mounting
    Clever
    May 2011
    Orange County, CA
    696
    Those look like they would work fine. Just know that the Easytouch panel is quite heavy and beefy, so be certain to tie the bolts into the studs in the wall. In a pinch, a handful of galvanized washers would also work to prevent crushing of the siding.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
