Results 1 to 11 of 11
Thread: Anybody using one of these?
    Sep 2010
    Noblesville, IN
    104
    http://www.amazon.com/Jandy-Ei-Chlorine ... +for+pools
    The installation looks like a breeze.
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    Oct 2012
    Central Ohio
    180
    Re: Anybody using one of these?
    I looked at those but if I remember correctly you have to replace the cell every 6-12 months.I think the cell costs a couple hundred bucks.I would verify that as it's been quite awhile since I looked at those.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Sep 2010
    Noblesville, IN
    104
    Thanks. I'll check that out.
    From what others have posted the install is reasonably easy, but not dramatically easier than installing a regular SWG. You still need to drill holes in a section of pipe and you have to have a long enough clear run of pipe where you can install the unit.
    Sep 2010
    Noblesville, IN
    104
    Thanks. I should have searched before posting but got excited I guess. I see you use the AutoPilot unit. Any problems with that?
    I've been very happy with my AutoPilot unit, especially since I stopped using the Total Control features and dropped back to the DIG-220 model. I have also heard really good things about their Nano unit. Keep in mind that the DIG-220 is more expensive than most, though it makes up for it with some nice extra features.
    Oct 2012
    Central Ohio
    180
    I couldn't find anything concrete about having to replace the cells yearly.I did find that you can get a 1,2or 3yr warranty depending on which vendor you buy from but I couldn't find out exactly what parts are warranted for the 2 &3yrs exactly.
    Rob
    SWCG,Uni-bead liner
    Borates
    Oct 2012
    209
    I have seen a few and most of them leak.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Sep 2010
    Noblesville, IN
    104
    Quote Originally Posted by PJ
    Good point. There must be some kind of seal where the parts clamp together and that would be a good place for a leak.
    Apr 2012
    Mason, Ohio
    119
    Jason - dumb question, but can you explain what you mean by "regular SWG"? I have one of these in my setup (except mine is hard-wired, so it's not that exact model) - PB's choice and I didn't question it. I'm just curious now how this differs from other SWGs.
    btw - HoleInOne - I've only had the pool for one season, but so far have not had any issues with the Jandy.
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    In both cases (Ei and conventional) the control unit is mounted to a nearby wall. In both cases there are complications if you don't have a sufficiently long section of straight pipe where the call/sensor can be installed.
    With a Jandy Ei you drill four holes in the pipe (at a specific spacing) and then clamp the cell and sensor packages onto the pipe. The control unit then plugs into an outlet.
    With a "conventional" SWG you cut out a section of pipe and then glue the cell (and depending on brand sensor package) onto the pipe. The control unit is then hardwired to the timer/automation unit/switch/circuit breaker (or other power source depending on situation).
