Thread: First Quote - McKinney, TX
    Mar 2013
    McKinney, TX
    11
    Pool:
    16' X 32'
    445 sq ft.
    87' perimeter
    2 anti-vortex drains
    Spa:
    28 sq ft
    18 inch high
    2.0 HP blower
    Equipment:
    Pentair IntelliFlow 3050 vs+svrs
    60 sq ft Pentair DE Filter
    400K BTU Pentair Heater
    3/4 hp for cleaner
    RB 320 Automatic Chlorinator
    Polaris 280
    1 500 Watt and 1 100 Watt light
    Includes:
    Color Quartz
    OK flagstone coping
    1 bench
    1 tanning ledge with 2 gushers
    420 sg ft Sun Deck decking
    29 ft of waterline boulders with 3 mini falls
    2 skimmers
    freeze guard
    pool miser automatic pool leveler
    pentair never-lube valves
    overflow line
    $49,917
    We are still debating the Nature 2 Fusion, Automatic Chlorinator, or SWG...and will probably add the computer controls.
    Any feedback is much appreciated....
    IG/Gunite with Quartz interior; 16,400 gallons; 3'6"x6' depth; OK flag coping; Sun Deck decking; tanning bed w/2 gushers; spa with double cut spillway; Pentair Intelliflo 3050 vs+svrs; Pentair 400K NG heater; Nature 2 Fusion sanitation; 60 sq ft DE filter; pentair easy touch 4 wireless; polaris cleaner; 1-500 watt pool light & 1-100 watt spa light; 23' waterline boulders with weeping wall.
    Re: First Quote - McKinney, TX
    Basically that looks like a nice setup and a fairly good price.
    I would certainly skip the Nature 2.
    You probably don't want both flagstone coping and a SWG. Personally I would go for paver coping and the SWG, but flagstone and no SWG is good also.
    Computer controls are very nice to have with a spa, though obviously it is more money.
    I would check to see if the SVRS option on the pump is required by code in your area, and if it is not required don't get that option. In every other way that is a great pump, but the SVRS option is occasionally known to cause problems. In most areas SVRS is not required when you have dual drains in both the pool and spa, but it does vary somewhat.
    420 sqft of deck isn't really all that much deck. Depending on the layout of your yard you might want to increase that substantially.
    TXALH,
    Looks like a good quote. We decided to go with SWG and OK flagstone with the expectations that it will need sealed at least once a year. I also just up graded for the easy 8 from the easy 4, which I had our PB builder trough in for free.
    McKinney, TX
    Pool build in progress, 14.8K gallons, OK flagstone copping (sealed), IG Gunite/Pebblesheen (Blue Granite), Pentair intelliflow 3050 vs - svrs, Pentair IC20 Salt-Gen, 60 sq ft Pentair DE filter, 400k BTU Pentair (NG) heater, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Pool (1) 500w (1) 100W Spa (1) 100w lights, (2) Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl (3) 12 scuppers on 12 x 31 raised beam, (2) Gushers on tanning ledge, and double cut spa spillway. controlled by easytouch 8
    http://www.troublefreepool.com/under...t56120-40.html
