Plumbing Question ??
Mar 5, 2013
300
Fort Worth Texas
I have to cut the gray pipe coming out of the heater to plumb in a SWG cell.
Is the Gray pipe CPVC ? I can see some copper specks through to gray.
If so what glue to use ?? Looks like there might be some kind of sealent used as the joint has a with ring around it . (See pic )
Its the pipe coming out the heater the shorter one..
Thanks for any assistance !!!
Depending on your climate, you will want to use a medium bond pvc. Hard bond cements will actually crack in cold temperatures and break pipes when it gets very hot out 100F+ because it does not expand and contract at all. Most All purpose cements fall into the All Purpose category.
